Pages: [1] 2 3  All   Go Down
Author Topic: towing  (Read 4182 times)
paintshoptec
  • cheadle, stoke - on -trent
    • 2002 cd v6 saloon
towing
« on: 17 February 2009, 22:13:44 »
thinking of changing my mig to 2.2 does anybody know what these are like for power when towing a caravan
thanks
MutantCav
  • Gainsborough
Re: towing
« Reply #1 on: 17 February 2009, 22:16:26 »
Dunno about the 2.2 but I found the 2.5 slightly underpowered on hills but then thats towing another Omega behind me and not a caravan...3.0 breezes it...
Martin_1962
Re: towing
« Reply #2 on: 17 February 2009, 22:36:34 »
I used to tow with a 2.0 - you rev the nuts off it up hill
2.6 is a lot easier.
puffa
  • Southampton, UK
Re: towing
« Reply #3 on: 18 February 2009, 09:04:43 »
The gas guzzling 3.2 tows with easy and  its easy to forget the caravan is there. mine sits at 60mph up hill and down dale.
Steve
Previously owned 2.5 v6 Reflection
bigall
  • merseyside
Re: towing
« Reply #4 on: 18 February 2009, 09:21:49 »
tow  a caravan with 2.2 petrol -auto
fuel consumption with van on back etc is high teens but then I do tend to drive at the max legal limit - especially in wales. no problem with hills
Autobox is fine - its had the latest ecu upgrade that stops the box searching for gears about 50/60 when towing.
I had an additional autobox oil cooler put in for peace of mind - has anyone ever looked at what the standard oil cooler in the radiator is - a length of pipe in the water - Ill try and find a pic of it from my rad that I cut up - most enlightening
finally a lot depends on the weight of the van and all accessories you intend to tow with. Caravan Club recommends a max of 85% of car weight
« Last Edit: 18 February 2009, 09:24:11 by bigall »
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
MutantCav
  • Gainsborough
Re: towing
« Reply #5 on: 18 February 2009, 09:24:25 »
v6 will give you some extra oomph though  :y
As said with Autos upgrade the ecu to latest software
Re: towing
« Reply #6 on: 18 February 2009, 09:28:58 »
...... Caravan Club recommends a max of 85% of car weight
That's just for the inexperienced isn't it?
MutantCav
  • Gainsborough
Re: towing
« Reply #7 on: 18 February 2009, 09:31:11 »
How heavy are caravans??!! Omega is a ton and a half, are caravans really that heavy that you have to consider its percentage weight against the car?
Re: towing
« Reply #8 on: 18 February 2009, 09:38:10 »
There are plenty of caravan out there that are far too big/heavy for an Omega.  :-?  :y  :y
MutantCav
  • Gainsborough
Re: towing
« Reply #9 on: 18 February 2009, 09:40:45 »
Wow, I thought they were only about 3/4 a tonne lol
Re: towing
« Reply #10 on: 18 February 2009, 09:43:00 »
That's a trailer tent!  ;D You don't even need brakes on a trailer up to 750 kg
My 2 berth is about 1300kg, but its around 17 ft (body length)
MutantCav
  • Gainsborough
Re: towing
« Reply #11 on: 18 February 2009, 09:45:34 »
Needing a v6 then lol
Re: towing
« Reply #12 on: 18 February 2009, 10:35:20 »
My 5 berth is somewhere around the 1700Kg mark IIRCC and my 3.0 tows it without missing a beat... Even averaged 19.8 mpg on a run to the Isle of Wight :y :y :y
Martin_1962
Re: towing
« Reply #13 on: 18 February 2009, 12:39:12 »
Ours is just over 920kg unladen then add 2 gas bottles, porch awning ect and it must be around 1200kg laden
Re: towing
« Reply #14 on: 18 February 2009, 15:09:51 »
I did mean fully laden, including food and clothing :y :y :y
Pages: [1] 2 3  All   Go Up
