Author Topic: Immobaliser Problem  (Read 1941 times)
villa
Immobaliser Problem
« on: 25 February 2009, 12:56:12 »
Afternoon all. Nickname Villa.  I am from swindon and my 1998 2ltr gls auto has decided on its own to activate the cars immobaliser causing the car to run like a bag of rollox ( spelling changed to protect the innocent).
Car now in garage. Can this be reset and would it cost a bomb?
Welung666
Re: Immobaliser Problem
« Reply #1 on: 25 February 2009, 12:59:58 »
Does it start and run?
« Reply #2 on: 25 February 2009, 13:00:00 »
If it runs at all then its not the immobiliser!
Welung666
« Reply #3 on: 25 February 2009, 13:00:26 »
That's where I was headed :y
villa
« Reply #4 on: 25 February 2009, 13:04:27 »
It turned over once then stopped.  garage in swindon (Mr Clutch) were it was recovered to plugged a diagnostic computer into it and thats what the computer came up with..
I thought it might be the idle control valve failed.  New cat fitted two weeks ago and it was also tuned and serviced.
Welung666
« Reply #5 on: 25 February 2009, 13:05:43 »
What codes did you get?
« Reply #6 on: 25 February 2009, 13:09:39 »
IF its an immolbiliser related issue then the ECU light will flash whn the car cuts out.
Has the key been taken apart recently?
Do you have a spare key you can try?
villa
« Reply #7 on: 25 February 2009, 13:20:10 »
Yes the ECU light did flash after it attempted to tick over but then cut out immediatly.
I only have one key for the car and a new battery was put into the fob about six months ago.  But the remote has never worked since my ownership of the vehicle one year ago so i lock and unlock the car by inserting key into lock as normal.
« Reply #8 on: 25 February 2009, 13:24:33 »
Its not the key or the remote, its the transponder that sits in the key.  If you have horseshoe style key, when you pull remote off, the transponder chip often goes flying...
villa
« Reply #9 on: 25 February 2009, 13:38:52 »
Its a horse shoe type key i think.  The key comes away from the main part.  How is this resolved if that is the cause please.
Welung666
« Reply #10 on: 25 February 2009, 13:41:01 »
If you haven't got the chip, then it'll be a new chip and a chat with a TechII but you'll need your car pass.
villa
« Reply #11 on: 25 February 2009, 13:46:41 »
Thanks for the info.
« Reply #12 on: 25 February 2009, 13:50:52 »
I have to say that the words 'Mr Clutch' do fill me with dread when it comes to the compitence stakes!
« Last Edit: 25 February 2009, 13:51:15 by Mark »
villa
« Reply #13 on: 25 February 2009, 13:52:56 »
I agree.  They have had the car for a week now and even have an ex Vauxhall Technician working for them.
« Reply #14 on: 25 February 2009, 15:03:00 »
Pull key apart, in the horseshoe should be a small chip (you'll see recess in the fob section for it to help you locate where it should be).
If its missing, check the carpets.
Page created in 0.036 seconds with 16 queries.
