Author Topic: Air con  (Read 1872 times)
Loch View
  • Dumbarton, Scotland
Air con
« on: 27 February 2009, 12:42:32 »
I've never really fiddled with A/C on a car other then regassing.
Is it correct that the front bit of the pump starts spinning when the A/C is on? Mine just spins along a little no matter what the A/C is set to  :-/
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
Welung666
Re: Air con
« Reply #1 on: 27 February 2009, 12:53:29 »
It's clutched so will spin faster when it's on full cold :y
Loch View
Re: Air con
« Reply #2 on: 27 February 2009, 12:55:49 »
Yes, but mine does not seem to kick in. There is no change in speed when the A/C is on.
I've had this before on a Volvo 850 and after a regas it worked fine.
Not sure if this will work for the Omega.
« Last Edit: 27 February 2009, 13:00:11 by Ruud »
Matchless
  • Nottingham
    • A white van
Re: Air con
« Reply #3 on: 27 February 2009, 13:15:08 »
With a/c off the front plate should be stationary, if it is spinning slowly then there is some clutch drag and the clutch will wear out very quickly.
When a/c is turned on the electromagnetic clutch should engage with a bit of a clonk, if it isnt then usual cause is low refrigerant oressure but it could also be a faulty clutch coil etc.
Loch View
Re: Air con
« Reply #4 on: 27 February 2009, 13:18:23 »
Mine still spins/drags with the a/c off. :(
Probably looking at a new/recon pump then?
« Last Edit: 27 February 2009, 13:19:13 by Ruud »
pauldmackay
Re: Air con
« Reply #5 on: 27 February 2009, 15:09:16 »
You don't need a new compressor! You can get the a new clutch kit and have it changed, it's a lot cheaper! I see your near Glasgow, I can give you a tel no to call to have it checked out and to get a price, he will come out to you.
Loch View
Re: Air con
« Reply #6 on: 27 February 2009, 15:15:18 »
Hi,
Yes, not far from Glasgow but (if possible) I do all the work on the car myself.
The clutch kit is also for sale, I hope?
pauldmackay
Re: Air con
« Reply #7 on: 27 February 2009, 15:18:27 »
yeah you can buy them but don't where though, had mine changed a few months ago.
