Author Topic: head swap  (Read 1612 times)
mantagte
  • great yarmouth
    • omega bmw maverick
head swap
« on: 27 February 2009, 11:27:41 »
a freind with a 3.0  just phoned he wanted to know if heads from a 3.2 will fit on a 3.0 bottom end  he bought a car which had tensioner failure and has been offered 3.2 heads cheap i said i dont know but will ask
markey mark
  • SLady bitshorpe north lincs
Re: head swap
« Reply #1 on: 27 February 2009, 11:29:53 »
iirc they will be fine matey  :y
mantagte
  • great yarmouth
Re: head swap
« Reply #2 on: 27 February 2009, 11:32:04 »
thanks markey mark will let him know
Re: head swap
« Reply #3 on: 27 February 2009, 11:38:44 »
They are indeed the same....but swap the t vents over from the old heads to be sure they match the oil pump setup.
mantagte
  • great yarmouth
Re: head swap
« Reply #4 on: 27 February 2009, 11:55:33 »
that chhered him up no end but he also wanted to know iwill the 3.0 cam covers fit or will he need the 3.2 ones
Re: head swap
« Reply #5 on: 27 February 2009, 12:02:13 »
3.0 ones will fit
mantagte
  • great yarmouth
Re: head swap
« Reply #6 on: 27 February 2009, 12:33:06 »
thank you
i got him into a mig next i will get him on here hopefully
mantagte
  • great yarmouth
Re: head swap
« Reply #7 on: 27 February 2009, 14:58:04 »
sorry to be a pain again
he has just phoned again
he has been offered some polished alloy ones off a vectra 2.6 will they fit he asks :)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: head swap
« Reply #8 on: 27 February 2009, 18:59:06 »
Yes, they will fit BUT they will not leak if the breathers get blocked .So it is much more important to make sure the breathers are cleaned prior to fitting and regular maintenance in the future. Also the vectra covers dont have the long neck on the oil filler so you will need a funnel to top up the oil.
Jaguar XJ6
Re: head swap
« Reply #9 on: 27 February 2009, 19:33:35 »
yes but, the holes around the plugs are large and square to accomodate the coil per plug setups so not ideal as crudd can get where you dont want it
