Author Topic: Breather box question  (Read 992 times)
topcat
  • Doncaster
« on: 28 February 2009, 21:44:16 »
Should you be able to hear air through the breather box on plenum when ticking over .I ask this because of my car running poorly .no codes with paperclip and a garage code reader thankyou   :(
Re: Breather box question
« Reply #1 on: 28 February 2009, 22:07:09 »
A quick way of checking for vac/intake leaks is to lightly spray carb cleaner in the affected area whist the engine is running, if/when the engine note changes it means the cleaner has been "drawn in" to the system and is being burned... you have now found the leak ..  just needs a little more spraying to pinpoint it .
Once you've done this , wipe the whole area down with paper towel and you have a diagnosed problem AND a nice clean engine  .. :)
« Last Edit: 28 February 2009, 22:07:47 by entwood »
topcat
  • Doncaster
« Reply #2 on: 28 February 2009, 22:10:10 »
 Thanks for that ill try it tomorrow
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #3 on: 28 February 2009, 22:26:22 »
but don't spray carb cleaner on hot exhaust manifolds!!!!!!! :exclamation
