Author Topic: part codes  (Read 1279 times)
slb
  • elland
    • 99 2.5 v6 cdx
part codes
« on: 01 March 2009, 15:43:47 »
hi does any one out there know the part code numbers for the e10 e-tork (or star bolts) that hold the dis pack to its mounting bracket as two of mine were not in good con when they finaly had to admit i was determind to get them out and they gave up takeing some threads with them. :y :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: part codes
« Reply #1 on: 01 March 2009, 15:47:50 »
8mm socket does the trick too ;)
think it is an E10
« Last Edit: 01 March 2009, 15:48:12 by Loo-knee »
slb
  • elland
    • 99 2.5 v6 cdx
Re: part codes
« Reply #2 on: 01 March 2009, 16:08:42 »
thnks i know what size is im after gm's part number so i can replace the knakerd ones :y :y
Re: part codes
« Reply #3 on: 01 March 2009, 16:14:23 »
I think the OP wants the P/N of the bolts themselves .... not the size !!
There are several quoted for the 2.5 engine...
SCREW, M6 X 30, IGNITION COIL TO CARRIER (NLS.- USE 11093953)    (11093951)
  Note: RANGE: NO BREAKPOINT INFORMATION AVAILABLE
SCREW, M6 X 50, IGNITION COIL TO CARRIER    11099321
SCREW, CSK., M10 X 25, IGNITION COIL CARRIER TO CYLINDER HEAD    11093991
HTH
« Last Edit: 01 March 2009, 16:15:15 by entwood »
slb
  • elland
    • 99 2.5 v6 cdx
Re: part codes
« Reply #4 on: 01 March 2009, 16:17:33 »
thanks :y will have some fun in the parts dept at vaux will have to take one down to get them to match it up for me. ;D ;D :y :y :y
