Author Topic: Tacho  (Read 1370 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Tacho
« on: 28 February 2009, 12:42:24 »
I have just noticed the tahco is not working , problem is I am not syre when it stopped .
I have just fitted the sat nav to my car so something may have happened while doing that  :-[ but I have also had the dash display out at the same sort of time .
I have pulled the dash display out and reseated it and it made no difference .
When I start the car I can see a very slight defection on the needle .
 Other than the needle not moving what other problems may this be causing the car runs fine  :y
Re: Tacho
« Reply #1 on: 28 February 2009, 19:22:57 »
We can stick tech2 on it which will show if its a tacho failure or a poor connection between car and dash
LFF64
  • HADDENHAM BUCKS
Re: Tacho
« Reply #2 on: 28 February 2009, 19:24:08 »
Any one have a decent wiring diagram please I am not sure which wire is the tacho feed looking in the haynes manual  :-/
Re: Tacho
« Reply #3 on: 28 February 2009, 19:25:23 »
Book of lies if you have one...
LFF64
  • HADDENHAM BUCKS
Re: Tacho
« Reply #4 on: 28 February 2009, 19:27:04 »
I have one but its not clear to me anyway which wire it is  :-[
Re: Tacho
« Reply #5 on: 01 March 2009, 10:16:18 »
Pop it over at some point, we can take a look.  If Tech2 is non conclusive, can always try a dash from either of mine (both are electrically compatible with yours)
LFF64
  • HADDENHAM BUCKS
Re: Tacho
« Reply #6 on: 01 March 2009, 20:58:34 »
Thanks to The Boy the tahco is now working again  :y it was something really stupid too ME   :-[ the connector that the display pushes in to had distorted slightly and was not making contact a bit of bending about and all working again  ::)
 Thanks again Jaime  :y
Re: Tacho
« Reply #7 on: 01 March 2009, 21:03:40 »
No probs :y
Did the MID get it's time back before you got home?
LFF64
  • HADDENHAM BUCKS
Re: Tacho
« Reply #8 on: 01 March 2009, 21:21:49 »
No not unless it was 0100  :D Sent you a pm  I did have another little problem  ;)
Re: Tacho
« Reply #9 on: 01 March 2009, 21:43:47 »
PM seen, just pondering on it...
Re: Tacho
« Reply #10 on: 01 March 2009, 22:02:53 »
i keep coming back to main connector in passenger kick panel.  may be worth checking its hurry seated, and no pins pushed up.
LFF64
  • HADDENHAM BUCKS
Re: Tacho
« Reply #11 on: 02 March 2009, 22:14:10 »
Every thing seems ok today  :-X I suspect it may have been the battry a bit low on the way home  . So thanks again  :y
