Author Topic: Thermostat Seal, where can I get the thick one?  (Read 1287 times)
Ironingboard
  • Edinburgh
« on: 03 March 2009, 09:56:48 »
After some searching around and using the power of UV and some coolant dye I think I've managed to find my leak, it looks like the thermostat seal is away again, even after using grey sealant as well.
Anyway I heard that there was two types of thermostat seal, a thin crappy one that VX supplies which is the one I fitted, which is leaking again, and a thicker multi level seal that’s a much better seal and shouldn’t give any problems.
Can anyone tell me where I can find the thicker one, I've tried VX but the only seem to supply the one type, the thin cheap one?
Re: Thermostat Seal, where can I get the thick one?
« Reply #1 on: 03 March 2009, 10:03:54 »
The bigger seal uses a different stat casting.
The best solution I have found is to use the oil cooler plate sealent in conjunction with the seal
Ironingboard
  • Edinburgh
« Reply #2 on: 03 March 2009, 10:18:56 »
Yeah thats what I did but its still leaking, think its leaking from the bolt area, I know one of the bolt holes is open at the bottom to the coolant area that the oil cooler sits in.
Any suggestions in applying sealant around that whole area?
