Author Topic: fuel line replacement  (Read 1414 times)
unlucky alf
  • worksop, notts
« on: 02 March 2009, 22:50:14 »
got an advice on the MOT today regarding fuel lines corroded, the tester says they have got special ends that clip onto the plastic pipes at either end, are these a vx only part & if so any idea on price & part numbers? also are they the same for diesel & petrol engines,,,TIA ;)
slb
  • elland
    • 99 2.5 v6 cdx
Re: fuel line replacement
« Reply #1 on: 03 March 2009, 15:09:25 »
ask at any good well known parts factors they should stock them to most garages :y
« Last Edit: 03 March 2009, 15:10:19 by slb »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 03 March 2009, 17:02:55 »
I thought that the fuel lines were made of blue plastic tubing - so how can corrosion be an issue?
True, there are connectors, and the complete system is available from the stealers - I've seen the parts diagrams there.
Not sure of price though.
unlucky alf
  • worksop, notts
« Reply #3 on: 03 March 2009, 17:26:40 »
i dont know if its because my one is an older model but definately metal pipes, just trying to find out the bore of it so i can replace with plastic as its cheaper & dont rot, at least it was only an advice thing on the MOT so got some time to sort it :y
« Reply #4 on: 03 March 2009, 17:51:16 »
Fuel hoses were all plastic as of model year 1997  :y
