Author Topic: Misfire 3.0 MV6  (Read 1813 times)
tomtr250
Misfire 3.0 MV6
« on: 03 March 2009, 22:16:32 »
Hi, I'm new to the forum and really like these cars but they are testing my patience!! I bought and elite estate at new year and the engine blew so I sold it and bought a BMW!! Hated that so I have bought an MV6. It ran great for about a week then started to misfire when it was on tickover, I cleaned the idle valve as suggested without success. Now the misfire has developed, over the last day or so it has misfired from cold and then cleared (except tickover) but now it is clearly down on at least one cyl, I bought some new plugs today and fitted 5, I couldn't get the cap off the rear l/h bank, some of the others were full of oil, so the cam box gasket is duff!!  It' still on 5? and rough as hell, anyone got any ideas of where to go next or get the cap off the back plug!!
Thanks
Tom :'(
Re: Misfire 3.0 MV6
« Reply #1 on: 03 March 2009, 22:26:44 »
Hi Tom,
Have you used the orange tool to try and remove the plug lead, it makes it easier  :y
tomtr250
Re: Misfire 3.0 MV6
« Reply #2 on: 04 March 2009, 07:30:39 »
Hi Pete,
Orange tool? Is that the bit of plastic on one of the front leads?
Tom
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Misfire 3.0 MV6
« Reply #3 on: 04 March 2009, 07:38:12 »
Yes it is mate :y
tomtr250
Re: Misfire 3.0 MV6
« Reply #4 on: 04 March 2009, 11:55:37 »
OK quick update, had AA to it and there is no spark to the rear cyl drivers side and the middle cyl passenger side, and arcing on rear cyl passenger side will it be coil packs??
Re: Misfire 3.0 MV6
« Reply #5 on: 04 March 2009, 12:14:19 »
DIS pack plus cam cover gaskets and breathers.
The DIS failure may well be due to the oil in the wells!
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
Re: Misfire 3.0 MV6
« Reply #6 on: 04 March 2009, 13:52:05 »
I had the same thing.
oil in plug wells weakened the leads so much that it eventually snapped. I did not notice the fact that it was running on 5 cylinders until it was too late and the dispack died.
got a pattern part replacement dis pack from autovaux for £55, 2 extra long leads from halfords and 2 lead adaptors. I had the new dispack fitted, not where it is supposed to be on the back of the engine, but instead on the top of the engine wedged in next to the oil filler neck. this changed an 8 hour job of screaming and shouting at the stupidly badly placed dispack into a much shorter and easier job.
placing the dispack here also means that if my HBV splits again the water wont drip onto the dispack as it is located elsewhere.
the other thing to check is your HBV, it might be that your HBV has split, leaking water onto your dispack causing a short. are you leaking coolant? do you get whisps of steam coming up from the driver's side of the skuttle??
If at first you dont succeed, Rev it harder!
Re: Misfire 3.0 MV6
« Reply #7 on: 04 March 2009, 13:55:50 »
Dis pack change is a 30-40 minute job......1 hour tops!
And given that the cam cover gaskets want doing at the same time,   about an additonal 10 mins!
bappy
  • HAVANT, Hants
Re: Misfire 3.0 MV6
« Reply #8 on: 04 March 2009, 13:57:11 »
maybe for you buddy but we had no ramps lol. couldn't get to the lil bugger to save our lives!
Re: Misfire 3.0 MV6
« Reply #9 on: 04 March 2009, 13:57:59 »
You dont need ramps, you just need to neal on the slam panel!  :y
Teebee
  • Slough
Re: Misfire 3.0 MV6
« Reply #10 on: 04 March 2009, 14:05:37 »
I changed my first pack this week and it took about 4 hours split over 2 days, it was split over 2 days because it took that long to clean the breathers!
Now that I know what to remove and where I could do it faster but no way in an hour. On the plus side I actually routed the pipes/cable properly so that I can now move stuff in situ to gain access.
Re: Misfire 3.0 MV6
« Reply #11 on: 04 March 2009, 20:14:15 »
Marks Dtm , if any mechanic other than you, can do in that period I'm ready to pay double ;D :y
tomtr250
Re: Misfire 3.0 MV6
« Reply #12 on: 05 March 2009, 17:26:27 »
Looks like i've started something here, I'm not sure I can be bothered to do it, anyone want a "w" reg MV6 for about £650, It's running "but not as we know it Jim" and sat on my drive having been recovered by the good ole AA
Page created in 0.065 seconds with 16 queries.
