Author Topic: Door cards.  (Read 1503 times)
Glassback
  • Sheffield, South Yorkshire
    • Face lift cdx dti
Door cards.
« on: 05 March 2009, 09:37:11 »
Can any one help?  Omega 2.2 CDX Dti on a 51 plate. I want to remove the drivers door card to have a look at the central locking. The plunger is sticking, and I want to give it some WD40.   Cheers.
laurie
  • headley down, hampshire
Re: Door cards.
« Reply #1 on: 05 March 2009, 10:54:38 »
Bumbazor
  • Worksop
Re: Door cards.
« Reply #2 on: 05 March 2009, 10:55:46 »
You need to prise out the red insert in the plunger, which will then release the plunger from the metal rod it connects to.
Glassback
    • Face lift cdx dti
Re: Door cards.
« Reply #3 on: 05 March 2009, 11:04:16 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152953579
should help
Absolutely brill. I did a search but found nothing, many thanks for your quick replies......... Colin......... PS. I can see this club being just as helpful and informative as the Stormers.
« Last Edit: 05 March 2009, 11:05:55 by Colin_Saunders »
Glassback
    • Face lift cdx dti
Re: Door cards.
« Reply #4 on: 05 March 2009, 12:25:59 »
Got to the motor and gave it some WD. but I think it's fubar, Does anyone know if they are they the same as Senny ones? Also just noticed front passenger one is not working either. Is this a common fault?
kevpuk
  • Poole
Re: Door cards.
« Reply #5 on: 05 March 2009, 18:37:07 »
Think that it is quite common.....my driver's motor did not work properly when I bought the car, got it fixed and now one of the rear's has packed up.....boo !
