Author Topic: duplex exhaust on a omega b ?  (Read 4890 times)
smartrs
  • out in the sticks
« on: 05 March 2009, 15:45:20 »
how easy is it to get hold of / fit a duplex system exhaust to the omega ?
nick v6
  • walsall / west midlands
Re: duplex exhaust on a omega b ?
« Reply #1 on: 05 March 2009, 15:50:41 »
you might do better having a look on the powerflow website and getting a stainless steel exhaust made
http://www.powerflowexhausts.co.uk/
smartrs
  • out in the sticks
« Reply #2 on: 05 March 2009, 16:07:07 »
yer always thought of power flow as a last resort , they can build just about any thing
nick v6
« Reply #3 on: 05 March 2009, 16:13:27 »
depending on your petrol tank
will depend on if you can go exhaust either side of the back
i can't on mine as i have the tank the sites at the back of the car and only leaves room at one side
iwas thinking of welding 2 cherry bombs together and using that as a back box
should sound fun :y
smartrs
  • out in the sticks
« Reply #4 on: 05 March 2009, 16:37:43 »
mine is like yours when i looked not much room on the drivers side at all
nick v6
« Reply #5 on: 05 March 2009, 16:51:31 »
yep
you can only put exhaust's on one side
i might try 2 cherry bombs and if it sounds crap ill try a 3litre back box
and see how that sounds :y
i might try the 3 litre back box as the baffles in mine have gone
smartrs
  • out in the sticks
« Reply #6 on: 05 March 2009, 16:57:59 »
is there no way of changing tanks ?
nick v6
« Reply #7 on: 05 March 2009, 17:04:04 »
don't know about changing the tanks
to much of a head ache in my books
plus changing the tanks will probly effect the fuel gauge as i think the tanks on the new type are smaller :-?
« Reply #8 on: 05 March 2009, 18:14:04 »
you can only put exhaust's on one side .....
Depends whether it a proper Irmscher wheel barrow handle style!  ;)
nick v6
« Reply #9 on: 05 March 2009, 18:15:38 »
i don't have the room to do that with mine as the tank is off set to the right
« Reply #10 on: 05 March 2009, 18:17:37 »
Aren't they all? ;) I've never looked under a car with wheel barrow handle Irmscher exhausts, but as Irmscher did them they must fit around the tank. I can't see them going to the effort of making up a tank to suit.
nick v6
« Reply #11 on: 05 March 2009, 18:20:54 »
i spoke to a mate of mine that makes stainless steel exhaust's
and he had a look under my car and said that i can only go one side
he said that vauxhall changed the tank on newer models
smartrs
  • out in the sticks
« Reply #12 on: 05 March 2009, 18:21:46 »
my tank is right over to the right there is not a lot of room down that side at all
Welung666
« Reply #13 on: 05 March 2009, 18:25:02 »
You can get pipes under the tank on the drivers side on the earlier models too, the pipes are ovaled to pass underneath. Specialist only though AFAIK, never seen any off the shelf.
nick v6
« Reply #14 on: 05 March 2009, 18:27:57 »
i wouldn't want to run pipes under the tank
its low enough as it is i would hate to hit a speed bump wrong and smack the exhaust into the tank :-/
