Author Topic: 2.5td Chip  (Read 7925 times)
largecol
  • Middlesbrough
  • I cant see my socks!!
2.5td Chip
« on: 23 February 2009, 17:50:39 »
Heloo guys, i`m giving very serious thought to chipping the old tractor now that i`ve put all the electrical faults to bed (at last)!!! I`ve seen lots of threads and advice on this issue on the forum - just wondering if anyones had any experience with this company http://www.chiptuning.at  They`re making all kinds of easy-fit extra power with low cost and low risk claims. Seams far too : good to be true - or is it?? To be honest i`ve never heard of a plug`n`play chip system before - but if it saves pulling out the ECU and not having to search the attic for me soldering iron i`m all for it!!  :D :D
Pssssst! The man in my avatar aint really me!!
Re: 2.5td Chip
« Reply #1 on: 23 February 2009, 18:25:13 »
drop a PM to 'omegatoy' i think he still has access to TD chips
Re: 2.5td Chip
« Reply #2 on: 23 February 2009, 18:29:19 »
I run a chip in my 2.5TD, as its rubbish without.
It makes the car much better, more drivable imho.
If you have an auto, your gearbox won't take it though, so its a non starter if you don't have a manual (unless you want to fit a stronger autobox)
largecol
  • Middlesbrough
Re: 2.5td Chip
« Reply #3 on: 23 February 2009, 19:05:50 »
Yeah i`ve seen the scary tales of boxes going all hari-kari!! Am i right in thinking its an ar35 i need? Can this be donored from any 3L mig, or are their specifics?? Still after info on these plug-in units - can it really be THAT simple?? :o
Re: 2.5td Chip
« Reply #4 on: 23 February 2009, 19:07:55 »
ar35, yup.  You need to reuse the torque convertor and bellhousing from your ar25 though.
The chips themselves are plug in, no real problem if you have an ecu with socketed chips.
Got bored with your link, crap site, lost interest in 5s, sorry
Omegatoy
  • UK
Re: 2.5td Chip
« Reply #5 on: 23 February 2009, 19:12:45 »
lol most of them are easy to fit as they just increase the fuel pressure,
which puts the injector pumps under severe strain and usually 'dangle berries's it within 10k!!! thsts why they are so easy to fit! and even worse to fit them you have to remove the ECU to identify the wires to connect them to!!!!!
diplo-matt
  • Scarborough
Re: 2.5td Chip
« Reply #6 on: 23 February 2009, 19:13:53 »
Having just chipped one myself here are the good points using the mentioned chip above.
Before - Fuel economy 25-30mpg around town, 45mpg on a long steady run
After - Fuel economy - 35-40mpg around town, 60mpg+ on a long steady run. Infact i managed just under 65mpg on a 200mile trip from cold over the weekend, but i was driving like a grandad.
Power is greatly increased especially low down. As far as i know the AR35 will simply plug and play, i think they have the same internals as the AR25 just better quality materials. If you go for the manual option then budget for a 3.0v6clutch.
The hardest part is finding someone who will fit it. The boards are pretty old fashioned and tough, but you still need a decent der-soldering station. I got a local computer repair to do it for 30 quid but it took a lot of ringing around before i could find somewhere.
Good luck
Re: 2.5td Chip
« Reply #7 on: 23 February 2009, 19:15:10 »
Good luck
Is that via MID or via manual calculation
diplo-matt
  • Scarborough
Re: 2.5td Chip
« Reply #8 on: 23 February 2009, 19:17:21 »
I have to admit thats via the computer. I used 18 litres of fuel over 189miles.
Re: 2.5td Chip
« Reply #9 on: 23 February 2009, 19:22:03 »
is that computer that says 18l used?  I'd be interested in how much you've actually used :y
kjf7
  • lincolnshire
Re: 2.5td Chip
« Reply #10 on: 23 February 2009, 19:56:13 »
been thinking about chipping my elite 2.5 td 1995 will it make much difference? only worry is that it's manual low geared rear wheel drive which makes it rubbish in snow and ice could'nt use it at all a couple of weeks ago would'nt even get it off the drive!
largecol
  • Middlesbrough
Re: 2.5td Chip
« Reply #11 on: 23 February 2009, 20:09:28 »
Mmm, so as long as i can source a box with a decent mechanic attached i`m sorted!!!lol There`s a couple of decent vx breakers around these parts so the hunt is on - any pointers as to cost of a box guys?? Also it may sound like a daft question but how`d you tell if a donor box is sound, other than driving the thing before its removed???  :-?
unlucky alf
  • worksop, notts
Re: 2.5td Chip
« Reply #12 on: 23 February 2009, 20:31:18 »
the gboxes [ar35] come up on here regularly, wouldnt like to quote prices though but some scrapyards are a bit "keen" on charging the earth, i would say anything between £70-£100 is a fair price but believe me itll be money well spent!, but dont forget a change of pants when the chip is fitted ;D you wont believe the difference :y
Re: 2.5td Chip
« Reply #13 on: 23 February 2009, 21:17:36 »
worth it, and not bad in snow (if you drive sensibly)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: 2.5td Chip
« Reply #14 on: 23 February 2009, 22:31:25 »
Chip it fellas - you'll wonder why you've not done it sooner!
Fuel consumption on mine is a (proven) constant 33mpg - no matter how or where it's driven (not tried it with the caravan in tow yet).
Several other members also get similar consumption figures.
Pages: [1] 2 3 4  All   Go Up
