Author Topic: Autobox level plug rounded off  (Read 1675 times)
jjleonard
  • stevenage
« on: 07 March 2009, 15:30:42 »
ARRGGGHHH. I got all my bits and pieces together, jacked the car up, only to discover that someone has been there before me and rounded off the 13mm head.
Any ideas what I can do now? access is extremely limited - I take it that I'll have to take the whole sump off, in which case how much atf do I need to refill it?
Cheers
John.
Re: Autobox level plug rounded off
« Reply #1 on: 07 March 2009, 15:38:56 »
Decent pair of vice-grips failing that mole-grips will do.
jjleonard
  • stevenage
« Reply #2 on: 07 March 2009, 15:41:49 »
Why is it I never think of the obvious things? Thanks Andy - I think this will have to be tried tomorrow.
« Reply #3 on: 07 March 2009, 15:51:50 »
Why is it I never think of the obvious things? .....
 :y  :y  :y  :y
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 07 March 2009, 19:28:10 »
Try grinding two flat edges on the nut,if access is possible with the grinder.
jjleonard
  • stevenage
« Reply #5 on: 08 March 2009, 14:31:55 »
Having spent two bloody hours on it today, I've had enough. Going to go to the local stealers tomorrow, pick up another plug, and beg the use of a ramp and a grinder to get the old plug off.
My major problem, as I've discovered today, is the cheapo halfords jack I have - it can't get the car high enough to use the high setting on my axle stands, so squeezing underneath is a challenge!
chrisdb
  • Chesterfield
« Reply #6 on: 08 March 2009, 17:37:10 »
I did see a tool yesterday in Machine Mart. They look just like a set of sockets but they have a sprial type shape inside. These lock on to the damaged nut and then turns just like a normal socket. Can't remember the price but might save you some pain. I'll have a look see if I can find it on web...
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
chrisdb
  • Chesterfield
« Reply #7 on: 08 March 2009, 17:41:35 »
Here you go... not sure if that is the intended purpose or even if it will work - maybe you could ask someone...
http://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set/path/
jjleonard
  • stevenage
« Reply #8 on: 08 March 2009, 17:54:59 »
Nice one - cheers chris.
I'm going to give it a go at the stealers tomorrow, then try this toolset if I run out of options!
jjleonard
  • stevenage
« Reply #10 on: 08 March 2009, 22:32:11 »
hmmm.
I picked up a 13mm version of that from B&Q this morning for just that reason - but unfortunately there isn't enough room 'above' the bolt to get the self locking head in!  :-/
