Author Topic: Handbrake/Fluid Level Warning light on the dash  (Read 1055 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 08 March 2009, 18:01:54 »
The ( ! ) one...It doesn't light up...
I've so far:
  • Changed the bulb in the dials
  • Checked the switch on the handbrake handle itself
  • Tested to see if it will light when I pull the fluid cap off
Nothing, not a sodding thing...  I've also checked all the fuses again and they are all right.
Any ideas where I might be best checking?  This is on the explod estate btw...  And it did pass its MOT with the light not working...
« Last Edit: 08 March 2009, 18:02:35 by PaulW »
Humbugs...
Re: Handbrake/Fluid Level Warning light on the dash
« Reply #1 on: 08 March 2009, 18:11:49 »
A light for t'handbrake is just a nice-to-have.  :y
Going back years ....... my Cavalier & Manta used to have a button on top of the master cylinder cap so you could test the float/switc/light. It appears to be missing on Omegas (can't remember about Senators  :-/)
PaulW
« Reply #2 on: 08 March 2009, 22:38:12 »
I tried the cap from the Elite (which I know works) and made no difference :(
Humbugs...
pauldmackay
« Reply #3 on: 08 March 2009, 22:42:33 »
try disconnecting the brake pad sensors one at a time, brake pads tcould be fine but you may have a electrical short, the light will go off when you've found the right one, just keep it diconnected until you need to change the pads, its worth a try, had this problem on a car before. ::)
« Reply #4 on: 08 March 2009, 22:43:46 »
Different warning light.  ;)  ;)
manual page 12  :y
« Last Edit: 08 March 2009, 22:46:04 by Andy_B »
PaulW
« Reply #5 on: 08 March 2009, 22:44:57 »
Was just goint to say, that would be check control, not dash :)
Humbugs...
« Reply #6 on: 08 March 2009, 22:52:42 »
I've so far:
Can`t you substitute the Elite switch to confirm that the plod switch isn`t faulty :question
Page created in 0.023 seconds with 16 queries.
