Author Topic: fitting quarter glass  (Read 1091 times)
gib
« on: 03 March 2009, 10:54:10 »
is there anybody who can tell me how to fit a osr door quarter glass back in to the omega 2.5 v6 as it locked me out off the car on its own answer was severe the hammer from a passing car so need to fit new one it came in its rubbers second hand so help is required gib
Re: fitting quarter glass
« Reply #1 on: 03 March 2009, 11:54:29 »
You need to remove the drop glass first then prise the rubber seal from the opening and slide the quarter pane towards the front of the car.
gib
« Reply #2 on: 04 March 2009, 08:01:11 »
thanks for that will have a go when the snow clears .. gib
gib
« Reply #3 on: 09 March 2009, 08:31:20 »
still no go in getting the glass in are we on the same glass the glass at the rear of the rubber is glued in .the glass came with the rubber attached and bonded to the rubber spent 5hrs on sat but cannot get  the top to spring into place had hair dryer on the rubber as it was cold and fairy liquid to help it to go in any other ieas gib
Loch View
  • Dumbarton, Scotland
« Reply #4 on: 09 March 2009, 08:45:28 »
If it is just rubber that has to pop in on the inside then put a thin piece of string (what the mrs uses to hang the washing up) all round in the rubber, push the class into place with the ends of the string on the inside and from the inside pull the string gently so the rubber 'lip' 'pops' over the frame. Make sure there is pressure applied on the window so it would be best to have someone else push the glass from the outside while you pull the string.
Hope this helps
« Last Edit: 09 March 2009, 08:47:43 by Ruud »
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
Page created in 0.026 seconds with 16 queries.
