Author Topic: Vacume ecu compressor??  (Read 1412 times)
steverubberduck
  • Kidderminster
  • MV6 BABY!!!!!!!!!!!
« on: 09 March 2009, 11:09:32 »
What are the little black plastic things on the back of the multi ram, plenum and by the air injection valve?
Just wondering, as i have a problem with my mv6.
Which way do they connect?
I have a copy of the breather set up in front of me, but it doesn't show in too much detail whicj way the pipes should be connected to them?
I'm presuming it would make a lot of difference if the breather pipes were connected to them the wrong way round??
Hope you all can understand my question
Re: Vacume ecu compressor??
« Reply #1 on: 09 March 2009, 11:13:25 »
Well, they sound like the vac actuator valves which are absolutlely nothing to do with the breather system
There is a drawing of how they connect up in the maintenance section.
On the valves, the vac feed should connect to the top and the output to the actuator the side.
steverubberduck
  • Kidderminster
« Reply #2 on: 09 March 2009, 11:18:54 »
that sounds like the little blighters, i have the drawing on my screen, but it doesn't tell me which way the pipes fit onto them.
but if you say it goes in on the top and out on the side, thats good enough for me...
just wan't sure which way tbh, trying to cross everybridge to sort the car...
