Author Topic: Windscreen washer prob  (Read 1323 times)
djm1964
  • Herts
  • The Boys Are Back In Town
« on: 07 March 2009, 19:47:25 »
Hi all , washers have packed up , the pump is making its normal noise , I disconnected the water pipe at the side of the bonnet , no water coming through when washers were tried , any advice as to where / how to fix or where to look next ? No water being dumped on the floor , when washers are tried, where is the pump situated and how do I get to it please, mechanic across the road owes me a favour so said he would have a look tommorrow , any help would be as ever much appreciatted.
Take care
Dave
Thin Lizzy are still the the best Rock band ever ! R.I.P Phil Lynott never forgotten .
Re: Windscreen washer prob
« Reply #1 on: 07 March 2009, 20:07:00 »
if I remember correct down the grill inside the bumper more close to the passenger side .. mine was donald and changed.. but check the water line for blocking..
« Reply #2 on: 07 March 2009, 23:28:34 »
Not surprisingly, the washer pump sits in the side of the washer bottle,  ;) The bottle is behind your grille, couple of self tappers at the top and it pulls up & off. As described here before, if you can hear the pump running but no water out of the jets, it's likely to be a gunged up filter that the pump is sucking from. Pull the pump sides ways to clear the bottle & then upwards off the grommet/strainer, remove strainer & washer it. Re-assemble & you'll be sorted.  :y  :y
djm1964
  • Herts
« Reply #3 on: 09 March 2009, 18:23:39 »
sadly strainer / grommet thing had perished and is now lurking somewhere in the fluid bottle , bought new one today from Vauxhall and job completed, car is booked in tommorrow for the auto fluid to be changed so I think thats all the maitenance now till the MOT in July , as always thanks for all the help and advice chaps.
take care
Dave
