Author Topic: Wheel alignment issues.  (Read 1874 times)
andyiow
  • Ryde, IoW
« on: 09 March 2009, 14:45:59 »
My car has just failed the MOT and the cause was tyre wear.
The front tyres have scrubbed the inside edges whilst the outside edges are showing virtually no wear. Has anyone got what the toe-in/out measurements that would suit as its the 2nd year in a row its failed for wear.
According to the local garage its fine but can not see it somehow.
Or if you have any recommendations in the Hampshire area would be grateful
Thanks
Re: Wheel alignment issues.
« Reply #1 on: 09 March 2009, 14:53:25 »
Thanks
Its not toe, its camber causing the wear.
Get it set to -1 deg 10''
ians
  • Reading
« Reply #2 on: 09 March 2009, 15:21:38 »
Micheldever Tyres at Micheldever Station have the full geometry kit and generally do a reasonable job.
« Reply #3 on: 09 March 2009, 15:30:42 »
have a google or a search top right its been well covered on here mate. As Mark says camber needs doing, but question is why? If your Mot station did their job and checked the wishbone bushes then they should be ok. But chances are they missed it and  the bushes have gone and or with age the springs suspension sags . Standard operating procedure is check wishbone bushes and stearing idler for play/ware and springs for broken ends then get full geometry set up. Dont bother waisting your time and money just tracking, it wont touch it. Hth
Loch View
  • Dumbarton, Scotland
« Reply #4 on: 09 March 2009, 15:34:59 »
as Chris says...probably wishbones :y
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
« Reply #5 on: 09 March 2009, 15:41:31 »
From the symptoms, its just camber. Whilst checking the bushes is prudent, there is nothing to suggest they have failed.
andyiow
  • Ryde, IoW
« Reply #6 on: 09 March 2009, 15:51:45 »
There is an advisary on the drivers wishbone bush bonding is starting to fail so will be replacing that before getting the camber sorted. Passenger side replaced last year.
I also thank for for correcting me, I knew what I wanted but could not think of the right word. :P
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #7 on: 09 March 2009, 15:56:08 »
Best to do both sides at same time :y
wheels-inmotion
« Reply #8 on: 09 March 2009, 22:17:39 »
If the wear is confined to about 10% of the tyres total width, then it's camber issue, as said -1d 10' is historically safe to resolve this.
Worn bushings would involve more area and generate a tramlining compliant, seemingly this is not the case.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #9 on: 09 March 2009, 22:19:13 »
take it to WIM most places reset the camber to factory spec which causes tyre wear
WIm use there own special figures
« Last Edit: 09 March 2009, 22:19:32 by tmx »
