Author Topic: Headlight Error Code  (Read 2535 times)
Mazucals
  • Aylesbury
« on: 08 March 2009, 11:34:45 »
S Reg - 3.0 ltr Elite.  Computer gives a warning - 'Headlight Field/Vision'.  Can't find it in the Owners Handbook.  Anyone know what it means ?
Re: Headlight Error Code
« Reply #1 on: 08 March 2009, 11:35:42 »
Either level sensors or servo motors.
Usually level sensor on front wishbone popped off
Mazucals
  • Aylesbury
« Reply #2 on: 08 March 2009, 11:45:38 »
Thanks, is that a garage job or just crawl underneath.
Welung666
« Reply #3 on: 08 March 2009, 11:49:12 »
Full right lock and look behind the passenger side wheel. Easy peasy job :y
davesink
  • Edinburgh
    • 2.6 MV6 Saloon
« Reply #4 on: 08 March 2009, 11:49:51 »
Put on full right lock and you should be able to see the sensor on the left wishbone
« Reply #5 on: 08 March 2009, 11:54:36 »
Not forgetting that there's another sensor at the back - same side.  ;)
Mazucals
  • Aylesbury
« Reply #6 on: 08 March 2009, 11:56:25 »
Ah, I can now see it but it looks solid enough.  I'll drop it by the Vauxhall dealer tomorrow.  Thanks again.
Welung666
« Reply #7 on: 08 March 2009, 12:01:24 »
You can't put the back wheels on full right lock though ;D
Check the rear sensor too Maz, same side as said already :y
« Reply #8 on: 08 March 2009, 12:02:18 »
You must have deep pockets! :o
'My' dealer charges around £80 just to plug into Tech II. Each sensor is about £50 new, if you need them, but your problem could also be the level motors in the headlamps themselves.
« Last Edit: 08 March 2009, 12:02:59 by Andy_B »
Mazucals
  • Aylesbury
« Reply #9 on: 08 March 2009, 12:35:30 »
I have also noticed that the headlights are suddenly very low so it might be that problem.
« Reply #10 on: 08 March 2009, 12:41:59 »
It could still be a level sensor though. Your lights could be low cos the sensor is telling them to go low. Your car needs plugging into a code reader of some sort. Are you local to any of the Tech II's on the site?
« Reply #11 on: 08 March 2009, 20:11:39 »
Rather than let Camden screw you over, do a bit more checking first.
As (presumably) both lights are low, that means servos are OK, so its most likely a sensor issue.
Are the little arms still in place on the sensors?
puffa
  • Southampton, UK
« Reply #12 on: 09 March 2009, 09:37:23 »
I had this problem even though the sensor looked visibly ok the centre popped out when i touched it, a new front sensor sorted it though.
Previously owned 2.5 v6 Reflection
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« Reply #13 on: 09 March 2009, 10:48:52 »
Hello people..
I too have this same issue although I dont need to put the headlights on for this warning to show its self. I've checked both links on the suspension armsv and all is well... would be interested to find out what you did to fix this in the end as its doing me head in now,,,,
« Reply #14 on: 09 March 2009, 13:09:53 »
Hello people..
Ideally get the codes read.  Not sure what members are near you with code readers - Jimbob?
