Author Topic: Over Fueling, 2.0Ltr Ecotec  (Read 1245 times)
jamesj
« on: 08 March 2009, 12:37:06 »
Anybody know about Over Fueling , My 1996 2.0Ltr Ecotec 16V Omega has just failed the MOT on Emmissions.
It has been standing for a couple of years, CO 7.42, HC 355, Lambda 0.82, this is far too rich for some reason ??
Lambda sensor has been replaced but this is something much bigger I think, maybe the fuel injectors ?? Its something that gives it Plenty of Fuel, like you have pulled out the Choke, ( The Old boys will know what I`m talking about )
Re: Over Fueling, 2.0Ltr Ecotec
« Reply #1 on: 08 March 2009, 12:50:09 »
That could be your answer. Did you give it a motorway thrashing before the MOT to clear the crap :) Works wonders, so I`ve been told ::) ::)
jamesj
« Reply #2 on: 08 March 2009, 19:00:15 »
 :D
I AM tempted to do that Just so I get my Monies worth out of the thing!!
 Problem is that, as I understand it, if you run rich on a car with a Catalizer then U are Likley to Stuff the Cat, SO i`m between a Rock & A Hard place, risk stuffing the Cat, and cost more expence  :-/
« Reply #3 on: 08 March 2009, 19:03:36 »
Have you `clipped it to see if any codes are stored :question http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
    • 530D M Sport, 330i Coupe
« Reply #4 on: 08 March 2009, 19:10:15 »
Could be the Coolant Temp Sensor, if it's giving the wrong reading the ECU will think the engine is cold and run it's 'fuel enrichment program' aka Choke!
« Reply #5 on: 08 March 2009, 19:45:36 »
Good point VXL. :y If it fails it can prevent the ECU from going into closed loop. This will result in a rich fuel mixture, excessive fuel consumption and elevated carbon monoxide (CO) emissions - which may cause the vehicle to fail an emissions test. Which reading the OP could well be the problem
« Last Edit: 08 March 2009, 19:46:22 by RobG »
jamesj
« Reply #6 on: 09 March 2009, 08:35:23 »
GOod points, NOw I am confused,
 From TopBuzz,  fault_codes.pdf I found that pins 5&6 should be connected with the engine runnning.
 SO I can try this also, do you think I can harm the ECU by trying different pins ??
 8-)
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #7 on: 09 March 2009, 13:02:51 »
with the engine switched off on the 2.0 16v
and i think its pin 4 and 6
« Last Edit: 09 March 2009, 13:04:29 by mantagte »
jamesj
« Reply #8 on: 09 March 2009, 23:25:13 »
Dont you just Love them , the Little Fury things,
 ""FIELD MICE""  !!!!!!!!!
www.flickr.com/photos/iolanthe/393355078/ Thanks for the Pic,
They Love Electrical Wiring dont they, So it Was a Lambda sensor that could not communicate,
Now I have a NEW MOT and perfect Emmissions
