Author Topic: My airbag light has come on HELP!!!!!!!!!!  (Read 4029 times)
trademeister
  • Rotherham
« on: 09 March 2009, 19:35:56 »
My airbag light has come on on my 99 2.5 cd. :'( :'( Its due for the mot and the garage says its not part of the test but theres obviously summat wrong!! >:( I hear alot about flashing codes up. How do I do this?? What do I look for?? Any help would be great. Thanks. Mark
oceansoul
  • Sunbury on Thames - Surrey
Re: My airbag light has come on HELP!!!!!!!!!!
« Reply #1 on: 09 March 2009, 19:52:44 »
It should be mot fail if the airbag light is on at the time of the test.
VX1
  • Reading, Berkshire
« Reply #2 on: 09 March 2009, 20:18:12 »
Did you take anything off that would cause the light to come on? If so just take to the garage and get them to turn it off or if you live near one of the Admi team you can ask them to do it.
Paul :y
Vx Trade club card holder
Halfords trade card holder
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #3 on: 09 March 2009, 20:27:58 »
no air bag or S R S (secondary restraint system) warning light will not fail an mot  would be worth checking conections under the front seats try unplugging then plugging back in but make sure ignition is off and key in your pocket first  :y
Just chilling in the sun. I wish back in the rain like everybody else
egg
  • Rutland Water
« Reply #4 on: 09 March 2009, 20:43:01 »
Why would it fail MOT if the airbag warning light is on at the time of the test?
Mine has just gone through MOT with it on and so has the wife's. Can't be bothered to get them reprogrammed.
Airbags are not tested on MOT.
nick v6
  • walsall / west midlands
« Reply #5 on: 09 March 2009, 20:54:32 »
from what i understand if there is any sort of warning light on the dash
then it will be an instate fail
    • 530D M Sport, 330i Coupe
« Reply #6 on: 09 March 2009, 20:58:12 »
Have you moved the drivers or passengers seat recently after it's been in the same position for a while?
« Reply #7 on: 09 March 2009, 21:03:15 »
Airbag is not mentioned in the MOT test....  and the fact that with the airbag light on the seatbelt pre-tensioners won't work is not an issue either .. as it specifically says that the pretensioners not working is not a reason to fail.
I cannot find any mention of warning lights as a fail issue other than the ABS light check.
http://www.motuk.com/mot_manual/index.asp
HTH
« Last Edit: 09 March 2009, 21:04:34 by entwood »
VX1
« Reply #8 on: 09 March 2009, 21:06:28 »
Just looked on the vosa site on there forum and it states,
That if the airbag is on then it will pass but it will be an advisory.
HTH
Paul :y
nick v6
« Reply #9 on: 09 March 2009, 21:08:08 »
HTH
Paul :y
your airbags and seat belt tensioners won't work in a result of a accident
which will be possibly dangerous to the people in the car
to me still should be a fail
« Reply #10 on: 09 March 2009, 21:31:24 »
HTH
Paul :y
Good job you're not an MOT tester then!  ;)
I put my Astra through a test with the air bag light on a couple of years ago, he never even mentioned it.
SRS is NOT part of a test.
« Reply #11 on: 09 March 2009, 21:33:01 »
need a code reader to find out whats wrong, and to reset it.
srs not mot failure
« Reply #12 on: 09 March 2009, 21:33:17 »
You need a code reader of some sort to talk to the car and to reset it when fixed. Your light will stay on till reset even if the fault is fixed.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #13 on: 09 March 2009, 21:43:20 »
only an ABS light on is a fail!
you need to get on a Tech 2 or a cheapo tech 2 to read the airbag codes
usually the sensors be careful though dont go playing with any of the airbag system until the battery has been disconnected for 30mins  to discharge the capacitors
trademeister
  • Rotherham
« Reply #14 on: 10 March 2009, 06:58:49 »
Ive added an elite leather interior. Has side airbags etc same as the cloth I taken out. Lights been on since then but none of airbags have been deployed all still intact. Is this the reason it needs resetting?? I just thought I could plug it all in as a replacement!! :'( :'(
