Author Topic: thermostat removal....HEEELLLPPP....!!!  (Read 4750 times)
Nickffc
  • Terrington St Clement, Norfolk
« on: 08 March 2009, 13:01:35 »
HI CHAPS...
having had a major water leak from what i thought was the water pump...it turns out is coming from the thermostat  :housing....well i think so....?
now...i have removed everything i need to gain access to the thermostat housing and have just removed the nut....(not tork bolt) that holds the connecting pipe to the housing.....but i cant remove the connecting pipe as the dipstick is in the way...?
i cant twist the connecting pipe round as it's still got the bolt stud through it from the block....
how the hell do you get that bugger off....?
any help will be grateful as this little problem is going to turn me to drink if i cant work it out....!!!!
N
DRIVE IT LIKE YOU STOLE IT......!!!!
3.0 MV6 Estate
1.9dti Astravan sportive
Re: thermostat removal....HEEELLLPPP....!!!
« Reply #1 on: 08 March 2009, 13:06:13 »
Have you had a look here. Might help http://www.omegaowners.com/forum/YaBB.pl?num=1229464812 :y
hotel21
  • The Kingdom of Fife
« Reply #2 on: 08 March 2009, 13:07:23 »
That will be whats affectionately known as the b*st*rd bolt that you have found then....   :D
Dipstick should move somewhat as the bracket thats in there too.  The transfer pipe will be stuck fast into the thermostat housing with crud buildup.  It should be a slick fit with an O ring in the housing but could have been 'done' before and sealant used.
Take care what you lever/twist as the securing bracket on the transfer pipe is easily broken, (as I found out when doing Kates car at Timbucks cambelt doo last year.....    :-[ )
« Reply #3 on: 08 March 2009, 13:55:05 »
Its a case of keeping the stat bolted to the block and working the transfer pipe around to get it to free off.
Other option is to keep the transfer pipe B-bolt fitted and detach the stat, then get soem good pliers on the stat and wiggle that end
Nickffc
« Reply #4 on: 08 March 2009, 22:09:00 »
well...
since my last post my internet connection went down and has only just come back.....???
after trying to get the thermostat out i decided to take off the black manifold spacer thing of to try to get a bit more room....then thought i'd better check again for the leak as i could see so much more.....
started to fill up with water and guess what........!!!
water leaking out of the area of the water cooler........!!!!! BUGGER!!!
as i couldn't get online to ask more questions i went out and got a copy of the haynes manual to see what is involved...!!!
anyone else had to take the oil cooler out????
so thinking first it was the water pump...then the thermostat, it turns out to be the oil cooler......? the leak seems to be coming from the oil pipe union closest to the front of the engine...?
i think i may as well change the cam belt while I'm at it.... a friend of mine has the locking kit that i can loan....!!
3.0 MV6 Estate
Martin_1962
« Reply #5 on: 08 March 2009, 22:27:02 »
When I do mine I'm going to cut the transfer pipe up to remove it then get the head off
Nickffc
« Reply #6 on: 08 March 2009, 23:01:14 »
3.0 MV6 Estate
« Reply #7 on: 09 March 2009, 08:29:21 »
Yes, thats the bastard bolt.
Move the PAS reservoir (beware ther is a small hole in the lid which should be plugged first) and in the process of doing this, you should see the B-bolt!
Once this is out, thats it, the dipstaick, engine mount and transfer pipe will be free.
The oil cooler plate seal is not to bad a job to do, just follow the oil cooler guide and undo the unions at the block end having removed the oil cooler housing (dont bend the pipes!)
And Martin, you do NOT need to cut the pipe at all, particularly whne taking the head off as the cambelt back plate will be out the way.
Martin_1962
« Reply #8 on: 09 March 2009, 10:51:17 »
But I have a nice shiney new one to go on!!!! ;D
Nickffc
« Reply #9 on: 09 March 2009, 20:05:38 »
this is the problem.....it's not a tork bolt...it's a stud sticking out of the block....? probably put in after the last this was done...lost the bolt so put in a stud...?i have managed to get the nut off the was on the stud so now the dipstick, engine hoist eye and thermo pipe are loose but because the stud is there nothing will slid out....?...i m gonna have to try and work out how to remove the stud from the block to get anything out...? but as you know....it's rather tight down there....!!!!
N
3.0 MV6 Estate
Nickffc
« Reply #10 on: 09 March 2009, 20:09:15 »
also......got the replacement thermostat, a couple of sealing ring for the oil cooler and water bridge.....but cant get hold of gaskets and "o" rings for the inlet manifold and plenum.....!!!!
is it worth putting it all back without new gaskets or "o"rings???
N
3.0 MV6 Estate
hotel21
« Reply #11 on: 09 March 2009, 20:13:11 »
Is there anough length on the stud to double nut it - where one nut is screwed on and another is also screwed on then both are locked very tightly against each other, then place a socket over both and then unscrew the stud??
Nickffc
« Reply #12 on: 09 March 2009, 20:28:52 »
exactly what i was thinking..... taking the day off work to try to get this sorted out.... either that of a buy the missis an oyster card.....!!!! :D
3.0 MV6 Estate
VX1
  • Reading, Berkshire
« Reply #13 on: 09 March 2009, 21:14:20 »
N
Yes put it all back together. You don't really need 'O' rings for the inlet manifold to plenum unless you have lost them or they are damaged.
HTH
Paul :y
Vx Trade club card holder
Halfords trade card holder
Nickffc
« Reply #14 on: 10 March 2009, 08:43:02 »
the bit I'm worried about is the flange gaskets both sides........there's none missing and don't seem to be damaged in any way...????
3.0 MV6 Estate
