Author Topic: Tools required for top end overhaul  (Read 1138 times)
Martin_1962
« on: 10 March 2009, 10:06:49 »
So far got
Large torque wrench
full set metric spanners & sockets
Enough Torx & star I hope
What else do I need?
I think I will need a new valve spring compressor, mine is ancient.
Also which sealants for where?
Will I need help?
The cambelt does scare me a bit.
Re: Tools required for top end overhaul
« Reply #1 on: 10 March 2009, 10:16:31 »
Er....
T55 and T60 (I think) torx bits (good ones as cheap ones will shatter on the head bolts) for head bolts and cam sprocket bolts.
Green snot sealer for the front cam bearings
Stem seals
A good valve spring compressor for multi valve engines
You wont need stem seal removal pliers in this case!
A litre of paint stripper for cleaning
Wet and dry plus some emery.
Grey sealent for the coolant plate and stat housing
Possibly some other odds and sods
Martin_1962
« Reply #2 on: 10 March 2009, 10:21:40 »
And I'll be wanting to borrow a cam locking kit :o :o
Do you have the part numbers for the snot and other sealant?
Isn't there a special spanner for the botto, pulley?
Head bolts - got a Halfords T55 - should I get a spare?
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 10 March 2009, 11:51:31 »
I would get a spare torx bit for the head bolts, see if you can find an impact one....it should be more resistant to the shock loads you will experience when trying to undo the old bolts.
You also need a long nuckle bar and possibly a pipe extension for it, and a 24?mm open-ended spanner to hold the camshafts whilst undoing the sprocket bolts.
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #4 on: 10 March 2009, 12:20:07 »
a bottle of radox for your bath  to ease your back muscles  when you have finished  ;D
Martin_1962
« Reply #5 on: 10 March 2009, 12:21:47 »
Got a few already - does help a little
Martin_1962
« Reply #6 on: 10 March 2009, 12:23:09 »
Will look for impact version
Got my long bar for the 1/2" socket drive, also got 24mm and 22mm spanners and quite a few imperial which could be requisioned.
« Reply #7 on: 10 March 2009, 13:08:02 »
Although yet to break one, not sure I'd trust a halfords torx bit on a head bolt  :-/
Martin_1962
« Reply #8 on: 10 March 2009, 13:24:25 »
Can you check the T60?
The garage over the road gets a Snap On van - might ask them for a T55
Martin_1962
« Reply #9 on: 11 March 2009, 12:48:08 »
Snap On T55 Ordered!!!!
Will get Halfrauds T60
    • 530D M Sport, 330i Coupe
« Reply #10 on: 11 March 2009, 12:56:06 »
Can loan you a camlock kit if you need one.
Martin_1962
« Reply #11 on: 11 March 2009, 12:57:08 »
Great - I will need one thanks! :y
