Author Topic: outside edge tyre wear  (Read 1437 times)
RiffRaff
  • Kingston Upon Hull
  • Life,s Bitch an then some
« on: 10 March 2009, 10:14:25 »
had both whishbones repalced for mot about three months ago,,noticed this morning that both outside edges on the front tyres have worn,, now is this just a camber problem or is it a a trip to some bugger that can do four wheel check
regards
Niel
cruise,rear blind,electric seats heated seats.climate,sat nav,kenwood HU,alpine V12 monoblock alpine V12 4chan focal components 2X12 jl subs .still need more toys
Loch View
  • Dumbarton, Scotland
Re: outside edge tyre wear
« Reply #1 on: 10 March 2009, 10:26:46 »
I'd say probably both but I think you're quite unique with having tyre wear at the outside, it's usually the inside on the Omega :y
« Last Edit: 10 March 2009, 10:29:46 by Ruud »
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #2 on: 10 March 2009, 10:37:07 »
regards
Niel
Did you have the wheel alignment and tracking done after the wishbones were fitted? If not, that will be the reason. Had my wishbones done at the weekend and the wheel alignment and tracking were way out afterwards.
« Reply #3 on: 10 March 2009, 10:40:19 »
Is the wear over a narrow section of tyre (10-20mm - camber wear) or a wider section (20mm+ - toe wear)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 10 March 2009, 13:11:17 »
regards
Niel
Personally, I'd be making a bee-line for the nearest reputable four-head wheel alignment specialists.
You've either got excessive toe-in and/or over-camber.
You should be able to get the settings corrected for less than the cost of a new tyre!
Then get a new pair of tyres fitted.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #5 on: 10 March 2009, 14:03:20 »
...both outside edges on the front tyres have worn...
Mine did the same after I renewed the wishbones.  I re-set the camber to the best of my ability but was aiming for zero degrees (can't find where I got that figure from now, it was 5 years ago) which is incorrect.
Unless you're happy to keep measuring your tyres and tweaking the camber, I would agree that a reputable person with the right equipment be entrusted with it.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
RiffRaff
« Reply #6 on: 11 March 2009, 15:41:32 »
trying to find one in hull anybody from my neck of the woods,, found an used one ??? did have tyres changed,,, an they supposidly checked an they said it was ok yerr right,,
regsrds
Niel
[/quote]
ians
  • Reading
« Reply #7 on: 11 March 2009, 16:02:54 »
note four wheel alignment is not the same as full geometry which is what it needs.  a typical tyre place does not have the kit or expertise to properly set camber.
