Author Topic: High pitched whistle - not kettle  (Read 1160 times)
oro
  • New Forest, Hampshire
    • 2000 facelift V6 Auto Est
« on: 11 March 2009, 18:23:27 »
Sorry should have given car spec - 2.5 petrol Auto reg 2000
Hi all,
First a big thank you for guiding me to starting problem - it was as informed, new starter motor, job done so back on the road.
BUT
Now I have a high pitched whistle each time I start, it only lasts 1-2mins then all is quiet till the next time I start, does it every time, everything else seems to work fine.
Any thoughts on the above would be gratefully received.
Thanks Mike
« Last Edit: 11 March 2009, 18:25:35 by oro08 »
ians
  • Reading
Re: High pitched whistle - not kettle
« Reply #1 on: 11 March 2009, 18:28:33 »
That will be the secondary air pump. Nothing to worry about (you can disconnect it if it really bothers you)
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 11 March 2009, 18:32:52 »
What he said^^^^^^^^ ;)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 11 March 2009, 19:04:38 »
Yep, I've heard this done before with no issues.
oro
« Reply #4 on: 12 March 2009, 08:37:53 »
Thanks all, that seems the way to go since there are no down sides!
I have looked through the maintenance section of the site and did not find any info on where the secondary air pump is, what it looks like or how to disable it.
If anyone knows, a link to the info would be great or general instructions.
Thanks Mike
MutantCav
  • Gainsborough
« Reply #5 on: 12 March 2009, 08:40:53 »
Its just behind the passengers side corner of the front bumper mate...look up and you will see it with the horn attached to it...it just unplugs  :y
oro
« Reply #6 on: 12 March 2009, 08:55:00 »
Thanks for the info.
