Pages: [1] 2 3  All   Go Down
Author Topic: How do I increase a trolley jack height safely?  (Read 5988 times)
jjleonard
  • stevenage
« on: 11 March 2009, 13:04:48 »
I've got an irritating Halfords trolley jack and axle stand kit - while the trolley jack will lift my mig high enough (380mm) to get axle stands under it at their lowest height, I can't get it high enough to use the second (higher) locking point on the stands.
Can someone advise on a SAFE way to raise the trolley jack height so I can use the higher setting on my stands? I can't comfortably get under the car on the lower setting, and as it looks like i'll have to do an ATF and filter change soon, I could use all the wriggle room I can get.
Cheers
John.
Martin_1962
Re: How do I increase a trolley jack height safely?
« Reply #1 on: 11 March 2009, 13:14:56 »
Blocks of wood - seem to work used to do it a lot
jjleonard
  • stevenage
« Reply #2 on: 11 March 2009, 13:16:40 »
Cheers - I'll have to dig some suitably heavy duty ones out. The last ones I used split as soon as they took the cars' weight!
« Reply #3 on: 11 March 2009, 13:18:31 »
Off cuts from fence posts work well
Tawfield
  • Berkshire
« Reply #4 on: 11 March 2009, 13:18:58 »
Id go along with the block of wood as long as your sensible with size,dont like Ive seen, use the convenient brick they can crumble.
jjleonard
  • stevenage
« Reply #5 on: 11 March 2009, 13:20:41 »
Cheers lads.
Am I right in assuming there's no current maintenance guide on changing an autobox filter, or changing the ATF? The only guide I can see talks about removing the level plug and topping up that way, which might be a pain in the backside for 7 litres of ATF.
« Reply #6 on: 11 March 2009, 13:27:20 »
Unfortunately that's the only way to fill up ::) ::)
jjleonard
  • stevenage
« Reply #7 on: 11 March 2009, 13:34:38 »
Looks like I might have to do a howto when I do mine....  :o
« Reply #8 on: 11 March 2009, 14:01:28 »
My fence posts are concrete.  ::)
I've got a short length of newal post which is excellent as an extention to my jack.  :y
Welung666
« Reply #9 on: 11 March 2009, 14:20:17 »
The safest way it to buy a bigger trolley jack ;D I use a 6" x 6" chunk of oak cut at about 8", been using it years :y
Loch View
  • Dumbarton, Scotland
« Reply #10 on: 11 March 2009, 14:24:53 »
I've bought a 5 ton bottle jack to get the car higher up for the stands...works a treat  :y
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
« Reply #11 on: 11 March 2009, 15:27:59 »
chunks of railway sleeper too, they just changed large sections of the line i use to concrete sleepers, i wonder if they will notice 1 or 2 sleepers missing from the massive piles on the side of the track  ::)
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 11 March 2009, 15:48:02 »
Daft question, why use axle stands? Surely ramps are ideal for this job?   :-/
« Reply #13 on: 11 March 2009, 15:51:48 »
With my car when I try to drive the car up the ramps (forward) various bits of the trim get in the way! :o :o
Therefore I always jack my car up steadily using blocks, axle stands and the ramps. ;)
« Reply #14 on: 11 March 2009, 15:54:29 »
I have done 2 ATF changes now, best way is using ramps, but use rear wheels.
Done an MV6 which is lower than normal, and that goes on fine if you reverse up...
Pages: [1] 2 3  All   Go Up
