Author Topic: Cruise control retrofit  (Read 1390 times)
John Lewis
  • Macclesfield, Cheshire
  • Macc is wack
« on: 12 March 2009, 13:47:19 »
Hi I just checked this guide by Simon_Omega after fitting a CDX indicator stalk with cruise into my V6 (manual) reflection:
http://www.omegaowners.com/forum/YaBB.pl?num=1197646817
The looms there, connected up no problems.
Thing is that guide makes no mention of any pedal switches but I was led to believe I needed some. I've just been looking in the footwell of my old CDX (auto) but can't find any switches, whats the score there?
I know I need to get it enabled on a tech2, but where are these swicthes, if anywhere? Need to find out soonish cos the motors going to the scrappers.
Thanks guys.
vauxfan2k
  • Western Isles
Re: Cruise control retrofit
« Reply #1 on: 12 March 2009, 13:55:00 »
The brake switch will be there already, up at the base of the brake pedal assembly, you should find taped up to a section of the loom a white 2 pin connector, this is for the clutch pedal. you should see a hole in the clutch pedal mounting for the switch to fit into.
If your car is a prefacelift then you do not need to have it enabled by tech 2. to test your cruise control in the meantime, short out the white 2 pin connector with a paperclip, take the car for a spin (over 30mph) and press the cruise button. it should hold the speed.
cheers  :y
hotel21
  • The Kingdom of Fife
« Reply #2 on: 12 March 2009, 13:56:27 »
That guide is for the later model, drive by wire, engines only.
For the standard v6, prefacelift types, check the following guide by another usefull chap....
http://www.omegaowners.com/forum/YaBB.pl?num=1166374649
John Lewis
  • Macc is wack
« Reply #3 on: 12 March 2009, 14:04:49 »
OK Cool. So I need the module too then  :-[
hehe such a numpty!
John Lewis
  • Macc is wack
« Reply #4 on: 12 March 2009, 14:42:53 »
cheers  :y
Nice one, vauxfan2k, I have a prefacelift so will check it oot!
