Author Topic: help with 'V' reg 2.0 Litre petrol Omega (auto)  (Read 2914 times)
Welung666
Re: help with 'V' reg 2.0 Litre petrol Omega (auto)
« Reply #15 on: 10 March 2009, 12:52:50 »
Best to get genuine, mabe someone local has a trade card?
« Reply #16 on: 10 March 2009, 13:12:03 »
Ok been and done the clip test and got 0335 as the result so I assume that the cranckshaft sensor is knackered. I have managed to drive home and the horrid grating/rattling noise has reduced but still there.
Is it practical to try and change it myself? and can anyone suggest a good place to get one other than a Vauxhall dealer.
stick with genuine part.
easy on 2.0 without aircon, fiddly with aircon.
doubt that is cause of metallic noise though! check cambelt!
mick the mend
« Reply #17 on: 10 March 2009, 13:35:07 »
hanks, mine has aircon, any guidance welcome
mick the mend
« Reply #18 on: 10 March 2009, 14:03:11 »
checked the timng belt - all is well no damage and seems tight
« Reply #19 on: 10 March 2009, 14:54:11 »
is the cam sensor intact? look between the cam sprokets with the cam cover off
mick the mend
« Reply #20 on: 10 March 2009, 15:29:50 »
It seems ok as far as I can tell, I would add a pic but I can't quite work out how
« Reply #21 on: 10 March 2009, 15:42:34 »
pay particular attention to tensioner and water pump.
mick the mend
« Reply #22 on: 10 March 2009, 15:54:27 »
they both seem ok, there is no play and they look fine.
Thanks to all of you for your time.
I will need to take off the crankshaft sensor to get a replacement, as I said I have aircon so how difficult is it to get at ? -any special tricks?
McJOHN
  • Prague (CZ)
« Reply #23 on: 13 March 2009, 07:28:21 »
Hi Mick,
this sensor is bad? Or only dianostic says if error in sensor?
Because 1) checkit diagnostic and 2) tested this separate sensor
same as here http://www.omegaowners.com/forum/YaBB.pl?num=1234899864/8#8
And, small question. How are old oil? If very old, includes much metallic dirtiness and impedance hereof sensor is changed.
Correct values  500-800Ohm.
Often helps dismount sensor, clearense and mount back.
I would have done that before change crankshaft sensor.
The mere fact exchanges sensosr is involvement, becaus off european cars cabel from off sensors is under oil tube. I donīt know as i version with RH steering.
If changed sensor, must ease away oil tube because of extraction cabel of sensor. Dirty work.
I hope if undesrtand me :-) Bay
« Last Edit: 13 March 2009, 13:57:29 by McJOHN »
Omega A C20NE; Omega B X25XE; Omega B X25XE
Martin_1962
« Reply #24 on: 13 March 2009, 09:41:12 »
Water pump or tensioner
Check it carefully
