Author Topic: help with 'V' reg 2.0 Litre petrol Omega (auto)  (Read 2912 times)
mick the mend
« on: 09 March 2009, 17:16:41 »
Can anyone offer help?
My engine is making horrible noises!
for a while my car has started ok and run ok for 15 - 20 mins and then has lost power and the EMU light comes on. The car still drives but pulls away very slowly from stationery. If after a while I stop the engine and re start, the light goes out and stays off and the car drives ok for as long as you like with no prob.
I have had a diagnostic done with a Snapon tester and it says there is a fault with the crank circuit.
I have just tried to start the car while it was a bit warm and it is really rough starting and making horrible rattling noises. Any idea what the noise might be, I was arranging to get the sensor replaced but the man I use is away at the moment so any advice would be welcome.
Cheers
Re: help with 'V' reg 2.0 Litre petrol Omega (auto)
« Reply #1 on: 09 March 2009, 17:19:19 »
with 2.0's its either the cam or crank sensors, just replace and all should be well again. Use geniune sensors.
mick the mend
« Reply #2 on: 09 March 2009, 17:26:37 »
thanks for the quick reply but it's the horrid metalic rattling that worries me - do you think  the sensor could have fallen apart?
« Reply #3 on: 09 March 2009, 17:34:00 »
Its possible, the cam sensor actually sits between the 2 cam sprokets, its possible thats fallen down or something and its rubbing against them.
Thats easy to check, just pop off the cambelt cover, or just remove the black ecotech strip, the sensor is at the front of the engine, you should see a wire popout out the fron the black strip.
I would have thought a dis lodged cam sensor would cause horrid noises, i think the crank sensor would just make a rubbing noise  :-/
But then again i am no expert
mick the mend
« Reply #4 on: 09 March 2009, 17:51:39 »
Cheers for that info, it makes me feel a bit better. If the crank sensor is buggered, how easy would it be for me to replace it myself? - (trying to save some money)
« Reply #5 on: 09 March 2009, 17:53:28 »
if you have metallic noises, start by checking the state of the cambelt tensioners!
« Reply #6 on: 09 March 2009, 18:26:00 »
Yep, check the cambelt and tensioners.
And do a paper clip test and post up the REAL fault codes!  :y
mick the mend
« Reply #7 on: 09 March 2009, 18:57:08 »
thanks for the advice you lovely chaps!
I will go back and have  look tomorrow where I have abandoned the poor thing, incidently will the paper clip test work on a 'V' reg? p brill if it will.
Again thanks for the help.
« Reply #8 on: 09 March 2009, 19:03:24 »
paperclip test will work
mick the mend
« Reply #9 on: 09 March 2009, 19:52:02 »
Can someone tell me where on the engine I am likely to find the engine code  for the paper clip test ? [edit][/edit]
« Reply #10 on: 09 March 2009, 19:56:19 »
you do a paper clip test to get the engine codes ;)
mick the mend
« Reply #11 on: 09 March 2009, 20:09:02 »
what I meant was where on the actual engine will the engine type details be so that I can tell what ECU type I have not the actual fault codes, I think it is a Ecotec engine but can't remember and It's about a mile to walk to my car so I want to be sure
« Reply #12 on: 09 March 2009, 21:09:02 »
Engine is the X20XE. As already stated, `clip it and post up the codes. I`d advise you to print off the details in the "How To" guide and take with you :y
mick the mend
« Reply #13 on: 09 March 2009, 21:15:59 »
thanks a lot - wish me luck tomorrow!
mick the mend
« Reply #14 on: 10 March 2009, 12:38:38 »
Ok been and done the clip test and got 0335 as the result so I assume that the cranckshaft sensor is knackered. I have managed to drive home and the horrid grating/rattling noise has reduced but still there.
Is it practical to try and change it myself? and can anyone suggest a good place to get one other than a Vauxhall dealer.
