Author Topic: Worn Wishbones !  (Read 1386 times)
Richard A
  • Aldridge, West Midlands
Worn Wishbones !
« on: 14 March 2009, 17:53:10 »
Both front tyres are worn on there outside edges, is this a typical characteristic of worn wishbones, ie along with the bangs and crashes from the front suspension on any type of broken road surface.
p.s. this is not just a tracking problem.
regards
richard a
richard a
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Worn Wishbones !
« Reply #1 on: 14 March 2009, 18:02:23 »
Usually inside edges
Richard A
« Reply #2 on: 14 March 2009, 18:16:56 »
Hello Timbuk, thanks for your answer, insides you say, oh sh1t !
I have a 'to buy' list for the mot in April, pair of wishbones, pair of drop links, one steering idler, total about £80 plus fixing.
Maybe I should check the track, ah' but it will be out after parts are fitted  :-/ :-/
regards
richard a
richard a
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 14 March 2009, 18:19:44 »
check the alignment after the wishbones they play a vital part in the alignment and when there duffed they cause the tyre wear
i took mine to WIM after i had the bushes wishbones done and all i needed adjusting was the Rear Toe and the camber to Tony's special figure ;D
