Author Topic: outside temp sensor  (Read 1010 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
outside temp sensor
« on: 13 March 2009, 11:55:03 »
hi my outside tempture reading started playing up the other day showing - temptures when it clearly wasnt and then it would come up F     C  so i ordered a new sensor but now all i get is the F   C  when i select tempture setting on the mid any ideas ?
2001 MV6 3.2 manual been converted from 2.6 auto
Re: outside temp sensor
« Reply #1 on: 13 March 2009, 12:53:02 »
You need to start tracing wiring back from sensor, suspect you'll find some damage (though pay close attention to sensor's connection)
Clouseau
  • Telford
  • Keeping the dream alive...
« Reply #2 on: 14 March 2009, 21:40:36 »
Yep, your sensor's probably fine!  I found one of the two blue wires from the sensor broken just before the multi-plug under the nearside passenger side.  The plug sits pretty low and in the splash zone so I guess it's vulnerable even though it's a waterproof jobby.  Try bridging the wires across the multi plug; it's most likely that the fault is around there.
