Author Topic: Knock in steering.  (Read 1354 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Knock in steering.
« on: 23 December 2008, 08:10:53 »
I'm getting a slight knock through the steering column when turning right.
It doesn't happen when turning left.
Checked all the obvious, no play anywhere.
I like red cars
hotel21
  • The Kingdom of Fife
Re: Knock in steering.
« Reply #1 on: 23 December 2008, 08:43:35 »
Is it a one off knock as you turn the steering wheel or a regular knocking as the wheels rotate and the car drives?
dpanic88
  • West Midlands
« Reply #2 on: 23 December 2008, 09:53:51 »
hi,
I had a knock on the passenger side, only when moving slow on turning close to full lock. It went to VX and they could not find any thing - in the end found it by having someone else turn the wheels while i checked the front - it turned out to be a worn part at the top of the suspension strut (you could see the whole top of the strut slightly move which inturn made the spring bounce and make the noise.).  The spring was complete no broken links
regards
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 23 December 2008, 12:01:46 »
A one off knock as I turn the steering wheel, seems to be coming from the steering wheel area.
I like red cars
amba
  • Medway towns
    • German V6
« Reply #4 on: 23 December 2008, 12:15:52 »
I had a similar problem when I first bought my car.It only made the noise on right turn,we traced it back to the steering coloumn,which I ended up just replacing as the noise was very annoying.When looked at base spline of old one it had started to rust(maybe from standing a while )and after fitting the new(2nd hand) one problem went.
ians
  • Reading
« Reply #5 on: 23 December 2008, 12:42:28 »
Is it worth a tweak on the steering box?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #6 on: 15 March 2009, 07:52:33 »
Fixed by The Man yesterday, tweeked up the steering box - result.
Thanks Mark.
I like red cars
