Author Topic: 3.0 and 3.2 questions...  (Read 2079 times)
GmasterT
  • Cambridge
  • does that drifting thing...
« on: 12 March 2009, 11:14:16 »
Right… I have made a bit of a schoolboy error and need to fix/replace my engine… but I have a few questions if anyone can help? Mainly what are the differences between..
3.2 and 3.0… is it just bore or stroke as well? (I have a spare 3.0 bottom end)
3.2 MV6 and 3.2 from a Monterey etc… same bottom end just different heads for the MV bit?
That is more or less it for now as I need to explore my options
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: 3.0 and 3.2 questions...
« Reply #1 on: 12 March 2009, 13:14:32 »
no the monteray is an ISUZU Derived engine 3.2 V6 190BHP
Out 3.2 is called the Y32SE 24v 217bhp
the moteray engine is completely different to the omegas so nothing will fit i dont think
« Reply #2 on: 12 March 2009, 13:15:48 »
Come on then ... own up ... what did you do .... (or not do :) ) .. ??
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 12 March 2009, 13:23:30 »
yeah have you cooked a V6 then? how ?????? i cooked a 2.5 by giving it far too much stick up a hill at 110mph it didnt like it and gave up  valve collapsed on my'n
« Last Edit: 12 March 2009, 13:23:56 by tmx »
« Reply #4 on: 12 March 2009, 13:26:17 »
What year is the 3.0 engine from?
GmasterT
  • Cambridge
« Reply #5 on: 12 March 2009, 17:39:38 »
3.0 is from a 96 omega elite...
I slightly drifted it a bit low on oil and have a knackered bottom end... schoolboy error! Want to get her sorted though :)
GmasterT
  • Cambridge
« Reply #6 on: 12 March 2009, 23:59:00 »
Ooooh, just found on ebay, how different is the vectra GSI 3.2?
Hopefully be looking into sump baffles and why it was trying to throw oil into the heads to stop this happening again!  :y
« Reply #7 on: 13 March 2009, 08:32:37 »
At that age engine the heads will not allow fixing of the coil per plug setup.
Martin_1962
« Reply #8 on: 13 March 2009, 09:42:38 »
You can make an engine out of yours and the Vectra one
GmasterT
  • Cambridge
« Reply #9 on: 13 March 2009, 18:16:42 »
Well I was thinking, over bore the 3.0 to 3.2 (if thats the only difference regarding capacity) Use that bottom end, rods and crank with the 3.2 pistons (I already have a set of Saab 9000 rods with the oil holes) and fit all the 3.2 head stuff on  :)
That may be a plan then... I notice the Vectra doesnt have the dual ram effort thingy, any reason for that? Must admit I drove a 3.2 vectra GSi years ago and it seemed a bit quicker, although the gears where definatly longer (that still doesnt make sense!)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 13 March 2009, 23:38:55 »
Vectra 3.2 is a Z32SE Omega V6 is a Y32SE im around 70% confident on this there are diferences between the 2
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #11 on: 14 March 2009, 14:48:48 »
I'm converting the Z32 for use in an Omega at the moment, have a pretty big list of parts and prices too if you need any info on that.  Mainly just seals, etc, but also alot is unit order, so I've got quite a few bits more than I need (like 5 seals when I need 1)
Humbugs...
GmasterT
  • Cambridge
« Reply #12 on: 15 March 2009, 10:05:38 »
Ah, cheers Paul!  :y
Well the engine is out, just waiting for an engine stand to assess the amount of damage  :)
