Author Topic: Replacing AC Evaporator  (Read 1051 times)
jon
  • oxford
« on: 15 March 2009, 09:22:52 »
I started the omega two days ago to hear the sound of escaping gas from inside the air vents. If i turned the AC to eco mode the hissing stopped and in auto mode setting the temperature to Lo now does not produce any increased cooling effect. I suspect the evaporator has a hole in it and the AC gas is escaping. Has anybody exchanged the evaporator? is it an easy job or is it burried deep in the dash needing a full dash out job which would not be worth the effort for me. My car is a year 2000 elite 3.0 final shape.
Re: Replacing AC Evaporator
« Reply #1 on: 15 March 2009, 10:45:28 »
AC needs discharging (specialist job) glovebox out, remove blower motor,disconnect refrigerant pipes at the bulkhead,remove expansion valve from evaporator then remove evaporator from distribution unit :'( :'( :'(. Not really a DIY job. >:(
« Reply #2 on: 15 March 2009, 11:07:02 »
If there's a hole in the evaporator, it doesn't need profesionally discharging .... it'll already be discharged!  ;)  ;)  :y
« Reply #3 on: 15 March 2009, 11:08:13 »
Dohhhhhhhh :-[ :-[
jonathanh
  • coventry
« Reply #4 on: 15 March 2009, 14:22:53 »
it may not be an ac problem.  the heater control unit is vacuum powered - if you've got a vac leak that's the sound you'll get.   one way of checking is to disconnect the vac supply, there are two vac hoses through the bulkhead - one to the HBV the other is vac suppy - disconnect it- if your hissing stops then you've got a vac leak in the heater control system.
Page created in 0.031 seconds with 16 queries.
