Author Topic: Mayo in oil filler neck  (Read 1782 times)
Bumbazor
  • Worksop
« on: 15 March 2009, 12:21:41 »
Doing some routine stuff now weather is nice and I found loads of Mayo in the oil filler neck. What else ahould I check and what migjt be the cause? Sorry for not searching but I'm using phone outside and it's a pain to use the Internet.
Also I think my coolant is drainig somewhere. I topped it up last weekend and now it's down an inch below level.
Could they be related?
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Mayo in oil filler neck
« Reply #1 on: 15 March 2009, 12:38:31 »
Mayo in filler neck is normal if a car just does short runs
nick v6
  • walsall / west midlands
« Reply #2 on: 15 March 2009, 12:43:10 »
oil and filter change and a good blast down the motorway should help :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 15 March 2009, 12:47:07 »
it happens alot on the v6 if you do lots of short runs and its very damp weather.
not always a problem.
check the oil on the dip stick for a better idea of whats happening mate.
Hows the water ?
Bumbazor
  • Worksop
« Reply #4 on: 15 March 2009, 12:52:36 »
Yeah it does short runs most of time. Also will be changing oil and filter soon.not found Mayo anywhere else.
Not found coolant leak though bit prob hbv.how could I check other than replacing it?
nick v6
« Reply #5 on: 15 March 2009, 12:54:15 »
you can do a pressure test
and check for any leaks that way
Bumbazor
  • Worksop
« Reply #6 on: 15 March 2009, 18:21:41 »
Took the time to clean breather tubes which had a bit of mayo in I didn't see when I did cam cover gaskets, also cleaned every bit I took off. I cleaned out that flat black thing on top of plenum and I noticed one of the pin sized holes in the round bit that shoves into the topside of the plenum was blocked.
It all got a good clean and now it sounds a lot better so I'm pleased with that.
Now how do I do the pressure test on the cooling system? Is it as simple as connecting a hose to something?
nick v6
« Reply #7 on: 15 March 2009, 18:24:04 »
« Reply #8 on: 15 March 2009, 18:24:16 »
a hole in A N OTher header tank cap & a tyre/schrader valve.  :y  :y  :y
Bumbazor
  • Worksop
« Reply #9 on: 15 March 2009, 18:50:05 »
Ok guys, thanks for all your help.
