Author Topic: fault codes help  (Read 982 times)
Terry_Seyforth
  • Great Yarmouth
fault codes help
« on: 13 March 2009, 16:35:38 »
Hi my omega has the fault light flash on and off when it feels like it, I have another post but no one is replying, I have the code and it says there is a problem with (1612 which points to immobiliser No or wrong signal immobiliser)  any ideas what this means.
Just a thought though the light comes on when I push the excelerator down faster than normal, so if you are driving and slowly excelerate the a high speed its ok but if you excelerate fast to a high speed the fault light comes on, something else I have noticed while trying to work out the problem, I pushed the speed right up, 70 or 80 miles an hour there seems the be a almost wind type noise coming from the back, could it be one of the exhaust boxes near the back,although there isnt a rumbling noise they usually make when blown, maybe the inner baffle, has gone, not sure, is it called baffle ?. its funny the fault light comes on when excelerating hard, I wouldnt have thought this would have been related to the immobiliser ?   unless that code is when checking, I have removed the inner alarm from the front under bonnet that sounds if you remove the batttery. Any ideas thanks :-/
« Last Edit: 13 March 2009, 16:37:18 by Terry_Seyforth »
DOH!!
Re: fault codes help
« Reply #1 on: 13 March 2009, 17:05:27 »
Not sure the 1612 is related you intermittent EML coming on.
Terry_Seyforth
  • Great Yarmouth
« Reply #2 on: 13 March 2009, 17:15:14 »
I have just been out in the car again, it seems to come on and off now when it wants, not related now to speed.  but it did initially start when I went a little faster on the way to work ?
DOH!!
« Reply #3 on: 13 March 2009, 17:33:19 »
The light that keeps coming on, is it diffinately the EML - shame one that flashes when you do paperclip test?
Terry_Seyforth
  • Great Yarmouth
« Reply #4 on: 15 March 2009, 11:49:22 »
yes the little orange car with spanner in middle. I didnt do the paper clip, i done the foot on brake and excelerator test.
DOH!!
Terry_Seyforth
  • Great Yarmouth
« Reply #5 on: 16 March 2009, 16:42:56 »
problem sorted, there was a electrical lead hanging of the air intake, lucky i spotted it. ;D
DOH!!
