Author Topic: Worn or warp break disks  (Read 1237 times)
Miggy24
  • Exeter,Devon
« on: 17 March 2009, 08:00:52 »
Hi all how can you tell if the front break disks are worn or warp.Are there any signs
nick v6
  • walsall / west midlands
Re: Worn or warp break disks
« Reply #1 on: 17 March 2009, 08:05:56 »
crap break pedal
uneven breaking
when braking the car may judder
hope that is of any help mate :y
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 17 March 2009, 08:07:55 »
The safest way to know is to remove one wheel. this way you can know for sure. If they have scratches change them immediately. There is nothing more important than properly working brakes. If the brake pads were worn out  and they touched the discs with metal surface it is extremly dangerous because the discs itself can brake in piexces
Miggy24
  • Exeter,Devon
« Reply #3 on: 17 March 2009, 08:08:47 »
Ok buddy also the steering is crap to it always pulls to the left.1 min it can be fine then it goes to pulling to the left again
« Reply #4 on: 17 March 2009, 08:16:23 »
Score marks are themselves not dangerous.  :-?
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 17 March 2009, 09:21:27 »
Because of the scoremarks the car can brake unevenly and even swing the hole car to the side if you hit the brakes hard.
nick v6
« Reply #6 on: 17 March 2009, 09:31:35 »
bottom arms or even steering idler
maybe even check your tyre pressures
yes it sounds daft but if one front tyre is low on pressure and you go over an uneven bit of round it can make th car pull over the uneven bit of road
VX1
  • Reading, Berkshire
« Reply #7 on: 17 March 2009, 09:47:52 »
Incorretc geomtry
Lower arms worn
steering idler arm worn
tyres worn
Calipers not working sufficently
Tyre pressure's
Paul
Vx Trade club card holder
Halfords trade card holder
