Author Topic: Air Leak  (Read 3997 times)
stemon
Re: Air Leak
« Reply #15 on: 15 March 2009, 20:26:50 »
Good point pete.  ;)   good luck djdaveyp85 , i have to go now.  :'(
steve
Pete Elite
  • Uxbridge, Middlesex
Re: Air Leak
« Reply #16 on: 15 March 2009, 20:30:33 »
My Mega is an early pre-facelift so doesn't have the longer plenum or the canister type oil filter as yours so best answered by someone who does but the plenum part should be an easy job :y.
djdaveyp85
  • Halifax, West Yorkshire
  • Geoffrey - RIP!
Re: Air Leak
« Reply #17 on: 15 March 2009, 20:41:16 »
Just went out and had a look, didn't realise it would only be 3 screws! O ring is missing. so problem fixed when i get one from vx 2morrow! Thanks for your help!
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #18 on: 15 March 2009, 20:43:13 »
JUst in case i've over looked something, how much is it to replace the whole part if the o-ring doesn't fix the problem?
Pete Elite
Re: Air Leak
« Reply #19 on: 15 March 2009, 20:52:47 »
If the o-ring was missing then i would say you've solved the problem when you get a replacement but in the event it doesn't then best to ask in the wanted section for a good second hand one :y.
Pete Elite
Re: Air Leak
« Reply #20 on: 15 March 2009, 21:13:54 »
http://www.omegaowners.com/forum/YaBB.pl?num=1204142232
 Try looking at the above if you find you can't get your oil filter off or it brakes while trying :(.
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #21 on: 16 March 2009, 10:39:17 »
OK i took another look thjis morning and the o-ring isn't missing but it is broken in 2 places, ordered one a vx with some new spark plugs as well and i'll pick them up later. On thing that did concern me when i took it off though was that was oil at the botton of the unit where the two little pipes connect into the bigger pipesa at the front of the engine. Could this be a sign  that the cam cover gaskets have gone?
Pete Elite
Re: Air Leak
« Reply #22 on: 16 March 2009, 20:01:34 »
No not a sign of leaking camcover gaskets but is the cause, oil will be found there as this is the engines breather system but would be advisable to give your breather system a clean out or you could end up with blown camcover gaskets if left untreated :y.
  Usual sign of leaking gaskets is oil in the plug wells :(.
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #23 on: 16 March 2009, 21:25:57 »
Haven't managed to get into the plug wells yet as i need to get an extension for my ratchet so i can get the coils off!
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #24 on: 17 March 2009, 19:47:48 »
Thanks everybody for your help, fitted the new o ring tonight and it has fixed the air leak, which has also fixed my high idle and my low mpg, he's now doing about 8mpg better! Cleaned out the breathers up here whilst i was in there and ran some carb cleaner through the air intake, al seems good now.
Going to change the spark plugs next but i need to find my extension for my ratchet first to get the screws off the coild pack as the fuel pipes are in the way!
