Author Topic: Air Leak  (Read 3990 times)
djdaveyp85
  • Halifax, West Yorkshire
  • Geoffrey - RIP!
Air Leak
« on: 15 March 2009, 19:58:10 »
Please see the photo below.
Basically i have an air leak at either side of the black thingy where i have arrowed. Sprayed carb cleaner around yesterday and i've pinpointed exactly where it is. it seems as though it is maybe a bit lifted at the front. Is there a gasket or o-ring or something underneath it which may need replacing?
« Last Edit: 15 March 2009, 19:59:08 by djdaveyp85 »
stemon
Re: Air Leak
« Reply #1 on: 15 March 2009, 20:07:20 »
Correct there is a big o ring under it.... will try get a picture.
Pete Elite
  • Uxbridge, Middlesex
Re: Air Leak
« Reply #2 on: 15 March 2009, 20:13:28 »
Hi, is the leak from underneath the part marked or from the seam in the part itself?
 The top of the part you've marked just clips on and there is a bolt underneath that hold the rest on to the plenum :).
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #3 on: 15 March 2009, 20:14:41 »
Will it be affecting the performance of my engine?
Pete Elite
Re: Air Leak
« Reply #4 on: 15 March 2009, 20:15:33 »
Yes :(.
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #5 on: 15 March 2009, 20:15:54 »
The black thing sits in the middle of the plenum and theres a small gap down either side of it. The air leak is in that gap at the front.
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #6 on: 15 March 2009, 20:17:16 »
its had the leak ever since it was fixed and my mpg has been terrible in the low 20's compared the the low 30's before! Hopefully fixing this will solve it?
stemon
Re: Air Leak
« Reply #7 on: 15 March 2009, 20:18:16 »
http://g.imagehost.org/0816/untitled_3.jpg
will prob be this o ring.   part number: 90467543  that should help vauxhall as long as they havnt changed the part no allready since january 09!!.  ;D
« Last Edit: 15 March 2009, 20:21:21 by stemon »
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #8 on: 15 March 2009, 20:20:01 »
Do you know the part number and price? And how easy a job it is?
Pete Elite
Re: Air Leak
« Reply #9 on: 15 March 2009, 20:20:25 »
Have you removed it from the plenum to see if the o-ring is intact or even there :question.
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #10 on: 15 March 2009, 20:22:04 »
No don't know how :(
is it easy? i could pop out and do it now!
stemon
Re: Air Leak
« Reply #11 on: 15 March 2009, 20:22:06 »
part number: 90467543  that should help vauxhall as long as they havnt changed the part no allready since january 09!!  shouldnt be no more than £1.50
mine was brittle and leaking aswell
« Last Edit: 15 March 2009, 20:22:41 by stemon »
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #12 on: 15 March 2009, 20:24:05 »
ON another note does anybody know how to get the lid off the oil filter capsule thingy? It only supposed to be 15nm but its well tight and i can't get the bugger off!
Pete Elite
Re: Air Leak
« Reply #13 on: 15 March 2009, 20:24:23 »
The part in the pic. that Stemom has supplied is in fact 2 pieces sealed together, are you sure that this seal has not come apart at the front where you say it's leaking from :question.
djdaveyp85
  • Geoffrey - RIP!
Re: Air Leak
« Reply #14 on: 15 March 2009, 20:26:19 »
Don't know tbh, i just know that i could hear an air leak and when i squirted carb cleaner around it the engine kind of "stalled" when it was sprayed there.
