Author Topic: Estate self levelling  (Read 1092 times)
daveball
  • Stoke-on-Trent
« on: 18 March 2009, 17:04:11 »
I have an Elite 3.0 Estate 1999, think its mini facelift.
I have seen the self levelling sensor on the back suspension and tubes going to the rear shocks and assume it is fitted with self levelling. I can't however find the compressor. Can anyone tell me where it is. I tried the FAQs. I have tried sitting in the boot but can't feel any movement or hear a compressor HELP!!
Dave
« Last Edit: 18 March 2009, 17:06:07 by daveball »
bigdods
  • Brackley
Re: Estate self levelling
« Reply #1 on: 18 March 2009, 18:02:18 »
IIRC its under the front bumper on the n/s. Its easy to check, just switch the ignition so all the dash lights come on but dont start the engine. After about 30 seconds the compressor will run for a few seconds and top up the suspension (even if you have no load on board). If you have a load in the back you should see it rise back to its normal level.
assuming the estate mini f/l is the same as my saloon f/l of course !
« Last Edit: 18 March 2009, 18:03:34 by bigdods »
« Reply #2 on: 18 March 2009, 19:33:04 »
As bigdods says ... but driver's side  ;)  ;)  ;)
bigdods
  • Brackley
« Reply #3 on: 18 March 2009, 21:06:51 »
SAI is on the nearside...yep so the compressormust be on the drivers side then... oopps.... all that whistling in the morning and I have SAI on the brain  :o
« Last Edit: 18 March 2009, 21:07:18 by bigdods »
« Reply #4 on: 19 March 2009, 11:13:08 »
drivers side front corner, look up between bumper and front wheel under air box. Also there is a fuse involved, dont know the number.
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #5 on: 19 March 2009, 12:04:56 »
fuse F27 under the steering wheel
