Author Topic: rear lights  (Read 1517 times)
AHerrington
  • Dronfield Near Sheffield
rear lights
« on: 19 March 2009, 17:41:05 »
Hi all, I have a problem with the whole nsr lights,
they are getting really dim or it might be my eye sight ;D, but deffinatelty getting duller. other side are fine but it seems to be the whole lot ( indicator brake), please help!!!
Cheers Andrew
Welung666
Re: rear lights
« Reply #1 on: 19 March 2009, 17:46:34 »
Daft as it may sound make sure the light board (plastic thingy with the bulbs in) is clipped home properly, my old chavalier used to go dim as it kept dropping out. Failing that check the 0v has a clean, tight contact.  :y
AHerrington
Re: rear lights
« Reply #2 on: 19 March 2009, 17:48:02 »
as you can probably tell i am not mechanically minded, whats 0v?
Re: rear lights
« Reply #3 on: 19 March 2009, 18:59:42 »
Earth or negative to most people!  :y  :y  :y
unlucky alf
  • worksop, notts
Re: rear lights
« Reply #4 on: 19 March 2009, 20:53:22 »
i believe its a brown wire thats got an eyelet on it thats nut & bolted by the n/s light unit, mine had problems as its also the 0v [ground/earth] for the heated rear window on my estate ;)
AHerrington
Re: rear lights
« Reply #5 on: 19 March 2009, 20:55:59 »
many thanks. do i need to just undo it clean it up and replace?
Agemo
  • Cleethorpes
  • Insignia
Re: rear lights
« Reply #6 on: 19 March 2009, 21:02:16 »
I would run a wire from the earth point, to the one on the other side.  Hope that makes sense.  :y
AHerrington
Re: rear lights
« Reply #7 on: 19 March 2009, 21:03:30 »
ok, i will give it a try tomorrow
