Author Topic: Location of TCU on a 2.6?  (Read 1330 times)
copcar_omega
« on: 19 March 2009, 23:41:50 »
Hi. Anyone know where the Transmission Control Unit (TCU) can be located on a 2.6 auto? :-? Cheers.
Re: Location of TCU on a 2.6?
« Reply #1 on: 19 March 2009, 23:45:41 »
Behind driver`s side kickpanel :)
« Reply #2 on: 20 March 2009, 08:24:06 »
As above, just above drivers kick panel.
I very much doubt its gone faulty though, but if you are replacing, it needs to be from same engine as yours...
copcar_omega
« Reply #3 on: 20 March 2009, 21:35:47 »
Cheers Guys. What I'm up to is to swap one out from a mate's good car that hasn't got a shift problem. Just doing some elimination. Probably just a new solenoid needed. Had it replaced before when I had the same problem about 8 months ago. Did the job then but the failure to shift into 3rd(?) has come back.
mkaminski100
  • Basingstoke
« Reply #4 on: 20 March 2009, 23:52:25 »
It's not the one on the bottom (around your foot). Look further up behind the dashboard and you'll see an aluminium box. Undo 2 plastic nuts and pull it. Rest is easy.
Remember that new engines 2.2, 2.6 and 3.2 have different solenoids and the ECU is not interchangeable with old models.
I suspect that there is a problem with 2-3 gear solenoid or it's sealing. Second thought would be a 2nd gear clutch housing.
