Author Topic: petrol flap wont open  (Read 2149 times)
madmax
  • costa del essex
« on: 22 March 2009, 00:48:20 »
went to fill up earlier and the petrol flap wouldnt open, got her home running on fumes. all i know is that it has a motor that runs of the central locking that locks the flap, but for some reason its not opening..help....
Pete Elite
  • Uxbridge, Middlesex
Re: petrol flap wont open
« Reply #1 on: 22 March 2009, 00:51:49 »
Hi,
   I think I'm right in saying you can get to the servo from in the boot behind the panel on the right side :y.
madmax
  • costa del essex
« Reply #2 on: 22 March 2009, 00:59:14 »
thanx for that ill have a look in the morning and let you no. ill see if i can source a new servo out as well. :y
« Reply #3 on: 22 March 2009, 01:08:15 »
Not sure what you will find, may just be a pull cord or something, but there is always an emergency back up.... :)
« Last Edit: 22 March 2009, 01:08:32 by floodm »
miggcddave
  •   south wales
« Reply #4 on: 22 March 2009, 07:44:13 »
hi mate to look at the petrol cap servo motor open right side cover in the boot where the first aid pack is . you can see the motor two bolts hold it in place ? my be the wire plug has came way from motor ? the motor pushes a locking rod in to fuel flap . if you remove this you can fuel up car / and look for problem . i hope this helps you good luck :y
« Last Edit: 22 March 2009, 07:46:33 by dave_evans »
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 22 March 2009, 10:00:32 »
Yup, the servos are prone to failure, easy to replace, get one from any Mig, from any scrappy.  :y
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #6 on: 22 March 2009, 10:38:40 »
what's that then?
take the cover off the pump in the floor of the boot and fill from there? :D
« Reply #7 on: 22 March 2009, 10:41:32 »
Mine stuck ages ago, I opened it from inside the boot as advised and gave it a squirt of WD and its been fine since! :y
ballcock50
  • South Wales
« Reply #8 on: 22 March 2009, 10:41:36 »
My father inlaw borrowed my car once and couldn't open the fuel cap had used the central locking before trying to fill it up.
madmax
  • costa del essex
« Reply #9 on: 22 March 2009, 10:50:22 »
yes!!! just filled her up managed to pull the servo arm back with a pair of pliers checked the connector was plugged in ok, sprayed with some wd40, servo is def dead. how do you get to the bolts to remove the servo dont seem to be a lot of room in there.. :)
miggcddave
  •   south wales
« Reply #10 on: 22 March 2009, 12:04:27 »
just on wheel arch you should have two cross head screws undo them and bkt will come off with servo motor and jobs a goodun :y
madmax
  • costa del essex
« Reply #11 on: 22 March 2009, 13:15:03 »
cheers for all your help guys didnt realise it was on a bracket, anyway its of now given it a good squirt with wd and worked briefly but dead slow, now its stopped working again. of now to the wanted section to see if any of you guys have got one for sale... :y
