Author Topic: Turns over but no spark  (Read 1321 times)
gmvphil
  • Greenwich
« on: 22 March 2009, 17:05:58 »
Hi
I'm a new member - need some help or advice.
1997 Omega (2.5  petrol auto)  - drove it ok on Friday night, no symptoms then, parked it up, but today it turns over but there's no spark at all. I called out the breakdown, who tried it with a battery booster pack, still turns over, but still no spark.  The immobiliser and alarm work as they should.
Mr. Breakdown suggested the coil pack....
I just did the paperclip test and got 12 (diagnostic start) and 31 (no rpm signal) - I expected those, but no other codes appeared.
Can anyone give any advice what the problem might be - would it be the coil/dis pack ?  If so, how much would I expect to pay for that to be fixed ?
Thanks for any help anyne can offer.
Phil
« Last Edit: 22 March 2009, 17:13:36 by gmvphil »
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Re: Turns over but no spark
« Reply #1 on: 22 March 2009, 17:32:14 »
The dreaded crankshaft sensor failed gives these symptoms
Omega 2.6 V6 Elite in Shiny Black
« Reply #2 on: 22 March 2009, 17:33:18 »
Crank sensor breaked mate ;)
gmvphil
  • Greenwich
« Reply #3 on: 22 March 2009, 17:45:08 »
Ah - thanks both.  I'd assumed that would show up a fault code, but I guess not ?   Any idea what sort of damage to my wallet that might create ?  I've previously used Mastertec in Romford who have done good work for me, but I've just  into London and might need to go more local.... just looking for an idea of a reasonable price for the job.
Cheers
Phil
Welung666
« Reply #4 on: 22 March 2009, 17:50:19 »
Do it yourself, easy enough :y There's a guide on here in the Maintenance section. Should be about £40-£50 for the sensor from VX on a TC.
jonathanh
  • coventry
« Reply #5 on: 22 March 2009, 17:51:13 »
cheapest way is do it yourself - see the guide
http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
I'm assured it takes about 15 minutes to do.  also recommended to use original VX parts - pattern seem to be unreliable
gmvphil
  • Greenwich
« Reply #6 on: 22 March 2009, 17:56:35 »
Wouldn't mind giving it a go but where I have to park there's no way I can do repairs so I might have to get it done....  if I did I guess I'm looking at at least an hour's labour then, if it takes 15 mins. ?  :y
gmvphil
  • Greenwich
« Reply #7 on: 22 March 2009, 19:45:55 »
Now I've realised that the crank sensor was only replaced 10 months ago.... is it likely it could go again so soon ?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #8 on: 22 March 2009, 19:47:13 »
If it wasn't a genuine one, then maybe...
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
« Reply #9 on: 22 March 2009, 19:47:37 »
Depends how the wire was routed, if its close to the exhaust manifolds it could melt  ;)
gmvphil
  • Greenwich
« Reply #10 on: 22 March 2009, 21:51:23 »
Ok right, thanks, I see - will have to check that then.
