Author Topic: hbv question  (Read 1105 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
hbv question
« on: 22 March 2009, 19:44:56 »
What actualy fails in the hbv I reasntly had the oil cooler fail on my 98 mv6 got that fixed by a star member of the oof thanks rob . But now I have to run with the heater on hi all the time other wise I get a coolent level warning on the dash and a oily smell comming into the car ( still trying to get the last of the oill out of the cooing system) I am guessing the hbv has failed and is leaking oily coolent when in operation ie bipassing heater when set to a lower tempture does this sound like the hbv to you guys ?
2001 MV6 3.2 manual been converted from 2.6 auto
Re: hbv question
« Reply #1 on: 22 March 2009, 20:19:12 »
There is  rubber diaphram setup that fails
bigtow
  • rochester kent
Re: hbv question
« Reply #2 on: 22 March 2009, 21:12:28 »
Hmmmm oil and rubber don't mix well so I guessing that's what the problem is
bigtow
  • rochester kent
Re: hbv question
« Reply #3 on: 23 March 2009, 11:53:57 »
hi all do the symptoms i describe sound like hb failure ?
Re: hbv question
« Reply #4 on: 23 March 2009, 11:59:46 »
Look for leaks from the back of the driver's side cylinder head with the heater at varying settings. Costs around £30 and takes around an to fit it. :y
