Author Topic: rounded taux bolt  (Read 3001 times)
nick v6
  • walsall / west midlands
rounded taux bolt
« on: 24 March 2009, 19:07:35 »
fitting the leather in the mig
and it looks like either it had leather in originaly or someone tried taking the cloth seats out
all the bolts on the drivers seat was fine
but the passenger seat all the bolts looked like someone has had a go at them
ive managed to get 3 of the 4 out but only managed 2 turns on the forth
any ideas to get the ruddy thing out :-/
Re: rounded taux bolt
« Reply #1 on: 24 March 2009, 19:21:48 »
How much vertical room have you got between torx head and seat when pushed right back or forward whichever the case may be :question
« Reply #2 on: 24 March 2009, 19:22:09 »
Vice-grips/Mole-grips  :-/
How about a 6 sided ordinary socket, maybe an Imperial socket that's a little smaller, and persuade it to fit?  ::)  :y  :y
nick v6
« Reply #3 on: 24 March 2009, 19:23:49 »
that last bolt is super tight
i dont fancy hammering the head of the bolt off cause i'm not sure if i change it afterwards
nick v6
« Reply #4 on: 24 March 2009, 19:24:55 »
push the seat right back i can get a straight run at it
the bolt i'm having trouble with is the bolt that is at the front closest to the centre console
« Reply #5 on: 24 March 2009, 19:30:38 »
Two options Nick. Do as AndyB suggests and force fit an undersize socket or get a 110mm grinder and cut a slot in the head wide enough to take a decent screwdriver. You would have to use heat in either scenario and just get a replacement bolt from one of the breakers.
chrisdb
  • Chesterfield
« Reply #6 on: 24 March 2009, 19:31:29 »
If space is a problem then unscrew the seat from the frame (4 bolts under the seat). If you can, then maybe mig-weld an allen key or something to the rounded bolt to turn it?
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
nick v6
« Reply #7 on: 24 March 2009, 19:32:02 »
ill have to give that a go tomorrow
raining here plus really dark :-/
« Reply #8 on: 24 March 2009, 19:58:38 »
..... If you can, then maybe mig-weld a .....
That's not a bad idea if it really comes to it. Instead of an Allen key, a M10 nut could be forced over the remnants of the Torx head and then plug weld the two together in the middle of the nut. It'll give you something to turn, and the heat of the weld will help ....... providing you don't set it on fire ..... that'd be tooooo much heat!  ;)  ;)  :y   :y
Welung666
« Reply #9 on: 24 March 2009, 20:06:15 »
Last one I took off that was rounded I hammered an undersized imperial socket on and it came off fine (I think the hammering helped!) AFAIK the socket is still on it ;D
