Author Topic: heater control buttons?  (Read 1221 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« on: 24 March 2009, 21:15:44 »
When you adjust the drivers heater control button shouldn't the passengers adjust at the same time without the need to reach across?
Cheers......
               Keith.....
hotel21
  • The Kingdom of Fife
Re: heater control buttons?
« Reply #1 on: 24 March 2009, 21:17:01 »
Only if you switch the other side off first, I think....
« Reply #2 on: 24 March 2009, 21:18:29 »
Cheers......
               Keith.....
Interesting question, as I seem to recall that with my pre-face lift Elite the drivers control did adjust the passengers setting at the same time. :-? :-?
On my current FL this does not happen. ::) ::) ::)
vauxsull
    • 3.0 Elite
« Reply #3 on: 24 March 2009, 21:19:43 »
it used to do this on my mini face lift too but thought maybe it all changed on the facelift for some reason?
« Reply #4 on: 24 March 2009, 21:22:51 »
On the face lift with cabin control.. press the drivers side button in once and the passenger temp control light goes out ... you now control the whole car temp .. press it again and their light comes back on and they can select a temperature of up to 3 degrees different to yours ..
vauxsull
    • 3.0 Elite
« Reply #5 on: 24 March 2009, 21:25:09 »
Well I'm going to try this now even though its pissing down and cold he he he
« Reply #6 on: 24 March 2009, 21:33:44 »
Correction .. the temperature difference should not be more than 2 degrees  .. :)
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Page 127
richy08
  • sheffield
« Reply #7 on: 24 March 2009, 21:59:43 »
if u press and hold in the drivers side then twist it will change the other one works on my 99 new shape one  :y
