Author Topic: Some more problems.  (Read 1132 times)
Glassback
  • Sheffield, South Yorkshire
    • Face lift cdx dti
Some more problems.
« on: 25 March 2009, 14:47:21 »
Hello, I replaced the drivers central locking motor last week, because it was fubar. But now it has started bouncing back off when I lock it with the key fob.It seems ok. when I use the key. Has any one got any ideas for a fix? The car is a face lift  cdx 2.2 dti. btw.
« Last Edit: 25 March 2009, 14:48:51 by Colin_Saunders »
mantahatch
Re: Some more problems.
« Reply #1 on: 25 March 2009, 15:19:43 »
I had a similar problem when I fitted mine. I found there is a small amount of adjustment in the mounting screws of the solenoid/motor. And by moving it slightly it stopped the bouncing back open.
HTH
Mike
Glassback
    • Face lift cdx dti
« Reply #2 on: 25 March 2009, 19:27:36 »
HTH
Mike
Cheers Mike, can you tell me which way you moved it?
Glassback
    • Face lift cdx dti
« Reply #3 on: 26 March 2009, 09:59:30 »
HTH
Mike
Thanks again Mike, Made an adjustment like you said, all sorted (for now)  :y
