Author Topic: HELP! damsel in distress. RE:Clutch release pipe  (Read 744 times)
tracy2000
« on: 26 March 2009, 14:45:43 »
Hi Guys, Just a quick question.
How do you release the clutch release pipe from the master cylinder of a 2lt 16v tourer S reg?
Thanks in advance
A stranded babe  :-*
« Last Edit: 26 March 2009, 16:23:47 by tracy2000 »
Re: HELP! damsel in distress. RE:Clutch release pipe
« Reply #1 on: 26 March 2009, 16:36:01 »
Clutch release pipe?
I am assuming you mean the hydraulic hose?
If you look between the master cylinder and the gearbox you will see a joint. Pull the retaining clip out and the joint will split.
